Hi, I try to run this code in TX2 and Xavier NX:
https://github.com/Stephenfang51/tracklite
In TX2, I use JetPack 4.3 and I can run the onnx_to_tensorrt.py smoothly.
In Xavier, I can only use JetPack 4.4 and when I run onnx_to_tensorrt.py I got this error:
AttributeError: ‘NoneType’ object has no attribute ‘serialize’
I try other onnx_to_tensorrt.py in:
https://github.com/jkjung-avt/tensorrt_demos
Everything is run ok.
So, I try to copy the yolo.trt file from the second link to run the first link.
Then I got error as follows:
[TensorRT] ERROR: INVALID_ARGUMENT: Cannot deserialize with an empty memory buffer.
[TensorRT] ERROR: INVALID_CONFIG: Deserialize the cuda engine failed.
File “run_tracker.py”, line 116, in
main()
File “run_tracker.py”, line 97, in main
tracker = Tracker(cfg, args.engine_path)
File “/home/xavier/tracklite/tracker/tracker.py”, line 24, in init
self.context = self.engine.create_execution_context()
Am I miss something?
