This is a known issue and is fixed in the newer TensorRT software.
| Failed to bind input tensor | 6 | 833 | May 18, 2022 | |
| Failed to bind input tensor. err and Failed to bind input tensor args. status | 4 | 1221 | February 17, 2022 | |
| Trtexec failed to generate engine (Internal Error) with DLA | 7 | 1085 | April 8, 2024 | |
| Error when use DLA with yoloV4 tensorRT | 7 | 970 | May 10, 2023 | |
| Cannot create DLA engine using trtexec on Xavier | 8 | 1055 | July 1, 2022 | |
| Failed to bind input tensor | 5 | 776 | October 18, 2021 | |
| Unable to build tensorrt engine with DLA enabled on Jetson Xavier NX | 7 | 354 | May 15, 2024 | |
| Can not make tensorrt work on DLA (Jetson Xavier) | 3 | 598 | October 18, 2021 | |
| NVIDIA Jetson Xavier NX with Jptpack 5.1.2, can not use DLA1 | 2 | 156 | May 30, 2024 | |
| Trtexec log problem and use DLA error on Jetson Xavier | 7 | 1592 | October 18, 2021 |
