OoenMP equivalent of OpenACC present?
When using OpenACC I use the present clause to indicate that something should already have a device copy. For example,
acc parallel loop present(are)
A runtime error is issued if arr is not found on the device. I’m wondering how this can be done with OpenMP?
Thanks,
Victor
Hi Victor,
Not directly. Though if you include a “map” clause, it will have the same “present_or” semantics as an OpenACC “copy” clause, but just wont issue an error if the variable isn’t present.
-Mat
Thank you, Mat! Then I’ll rely on profilers and NVCOMPILER_ACC_NOTIFY to find unwanted memory transfers.
Victor
