• Hardware Platform (Jetson / GPU) T4
• DeepStream Version 5.0
• TensorRT Version 7.0
• NVIDIA GPU Driver Version (valid for GPU only) 440
• Issue Type( questions, new requirements, bugs) bugs
Hi, we used test5 with KAFKA, we found our program always shut down after serveral hours, it just looks liake this:
Finally we found that it might be a memory leak, we did a set of comparative experiments and were surprised to find that the memory footprint of the kafka set had reached an incomprehensible size.
config:
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=4
nvbuf-memory-type=0
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=4
nvbuf-memory-type=0
[sink1]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM - Custom schema payload
msg-conv-payload-type=1
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_kafka_proto.so
#Provide your msg-broker-conn-str here
#msg-broker-conn-str=<host>;<port>;<topic>
#topic=<topic>
#msg-broker-conn-str=221.236.26.29;9092;test
msg-broker-conn-str=127.0.0.1;9092;foreign_matter_stat
#msg-broker-conn-str=192.168.1.216;9092;head_count
topic=foreign_matter_stat
#Optional:
#msg-broker-config=../../deepstream-test4/cfg_kafka.txt
source-id=0
[sink2]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
## only SW mpeg4 is supported right now.
codec=3
sync=1
bitrate=2000000
output-file=out.mp4
source-id=0
# sink type = 6 by default creates msg converter + broker.
# To use multiple brokers use this group for converter and use
# sink type = 6 with disable-msgconv = 1
[message-converter]
enable=0
msg-conv-payload-type=0
# Name of library having custom implementation.
#msg-conv-msg2p-lib=<val>
# Id of component in case only selected message to parse.
#msg-conv-comp-id=<val>
# Configure this group to enable cloud message consumer.
[message-consumer0]
enable=0
conn-str=172.19.207.65;9092
config-file=cfg_kafka.txt
subscribe-topic-list=broadcast
[osd]
enable=1
gpu-id=4
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=4
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
attach-sys-ts-as-ntp=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=4
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
nvbuf-memory-type=0
model-engine-file=../models/resnet18_detector.engine
labelfile-path=labelzawu.txt
config-file=config_zawu.txt
#infer-raw-output-dir=../../../../../samples/primary_detector_raw_output/
[tracker]
enable=0
tracker-width=600
tracker-height=288
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
#ll-config-file=tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=4
#enable-batch-process applicable to DCF only
enable-batch-process=0
[secondary-gie0]
enable=0
gpu-id=4
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0;
batch-size=1
config-file=../../../../../samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt
labelfile-path=../../../../../samples/models/Secondary_VehicleTypes/labels.txt
model-engine-file=../../../../../samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
[secondary-gie1]
enable=0
gpu-id=4
gie-unique-id=5
operate-on-gie-id=1
batch-size=1
config-file=../../../../../samples/configs/deepstream-app/config_infer_secondary_carcolor.txt
labelfile-path=../../../../../samples/models/Secondary_CarColor/labels.txt
model-engine-file=../../../../../samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
[secondary-gie2]
enable=0
gpu-id=4
gie-unique-id=6
operate-on-gie-id=1
batch-size=1
config-file=../../../../../samples/configs/deepstream-app/config_infer_secondary_carmake.txt
labelfile-path=../../../../../samples/models/Secondary_CarMake/labels.txt
model-engine-file=../../../../../samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
[tests]
file-loop=0
[source0]
enable=45
type=3
uri=rtsp://xxx.xxx
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
#uri=rtsp://192.168.1.112:8554/test
num-sources=1
gpu-id=4
nvbuf-memory-type=0
#pad_index=11
#camera_id=500
# smart record specific fields, valid only for source type=4
smart-record=0
# 0 = mp4, 1 = mkv
smart-rec-container=0
smart-rec-file-prefix=rtsp_record
smart-rec-dir-path=/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/zawu/output
# video cache size in seconds
smart-rec-video-cache=100
# default duration of recording in seconds.s
smart-rec-default-duration=30
# duration of recording in seconds.
# this will override default value.
smart-rec-duration=30
# seconds before the current time to start recording.
smart-rec-start-time=30
# value in seconds to dump video stream.
smart-rec-interval=30
drop-frame-interval=20```
