Looks like the post got flagged as spam. Not sure why. Though here’s what you posted:
It looks as follow. I see that the paths for the ucx and cuda are hardcoded. Can they be overridden?
nvhpc_2023_2311_Linux_x86_64_cuda_multi/Linux_x86_64/23.11/comm_libs/12.3/openmpi4/openmpi-4.1.5/bin/ompi_info
Package: Open MPI qa@sky2 Distribution
Open MPI: 4.1.5
Open MPI repo revision: v4.1.5
Open MPI release date: Feb 23, 2023
Open RTE: 4.1.5
Open RTE repo revision: v4.1.5
Open RTE release date: Feb 23, 2023
OPAL: 4.1.5
OPAL repo revision: v4.1.5
OPAL release date: Feb 23, 2023
MPI API: 3.1.0
Ident string: 4.1.5
Prefix: /lus/h2resw01/scratch/syla/nvhpc_2023_2311_Linux_x86_64_cuda_multi/Linux_x86_64/23.11/comm_libs/12.3/openmpi4/openmpi-4.1.5
Configured architecture: x86_64-pc-linux-gnu
Configure host: sky2
Configured by: qa
Configured on: Sat Oct 14 04:04:36 UTC 2023
Configure command line: '--enable-shared' '--enable-static' '--without-tm'
'--disable-mpi-cxx' '--disable-wrapper-runpath'
'--without-libnl' '--without-verbs'
'--without-xpmem' '--without-cray-xpmem'
'--enable-mpirun-prefix-by-default'
'--with-libevent=internal' '--with-slurm'
'--with-ucx=/proj/nv/libraries/Linux_x86_64/23.11/openmpi4-12/238661-rel-4/comm_libs/12.2/openmpi4/openmpi-4.1.5'
'--with-cuda=/proj/cuda/12.2/Linux_x86_64'
'--enable-mpi1-compatibility'
'--enable-mca-no-build=btl-uct'
'--prefix=/proj/nv/libraries/Linux_x86_64/23.11/openmpi4-12/238661-rel-4/comm_libs/12.2/openmpi4/openmpi-4.1.5'
'--with-wrapper-ldflags=-Wl,-rpath,$ORIGIN:$ORIGIN/../../lib:$ORIGIN/../../../../../compilers/lib:$ORIGIN/../../../../../../compilers/lib'
Built by: qa
Built on: Sat Oct 14 04:17:24 UTC 2023
Built host: sky2
C bindings: yes
C++ bindings: no
Fort mpif.h: yes (all)
Fort use mpi: yes (full: ignore TKR)
Fort use mpi size: deprecated-ompi-info-value
Fort use mpi_f08: yes
Fort mpi_f08 compliance: The mpi_f08 module is available, but due to
limitations in the
/proj/nv/Linux_x86_64/238661-rel/compilers/bin/nvfortran
compiler and/or Open MPI, does not support the
following: array subsections, direct passthru
(where possible) to underlying Open MPI's C
functionality
Fort mpi_f08 subarrays: no
Java bindings: no
Wrapper compiler rpath: rpath
C compiler: /proj/nv/Linux_x86_64/238661-rel/compilers/bin/nvc
C compiler absolute:
C compiler family name: PGI
C compiler version: 23.11-0
C++ compiler: /proj/nv/Linux_x86_64/238661-rel/compilers/bin/nvc++
C++ compiler absolute: none
Fort compiler: /proj/nv/Linux_x86_64/238661-rel/compilers/bin/nvfortran
Fort compiler abs:
Fort ignore TKR: yes (!DIR$ IGNORE_TKR)
Fort 08 assumed shape: yes
Fort optional args: yes
Fort INTERFACE: yes
Fort ISO_FORTRAN_ENV: yes
Fort STORAGE_SIZE: yes
Fort BIND(C) (all): yes
Fort ISO_C_BINDING: yes
Fort SUBROUTINE BIND(C): yes
Fort TYPE,BIND(C): yes
Fort T,BIND(C,name="a"): yes
Fort PRIVATE: yes
Fort PROTECTED: yes
Fort ABSTRACT: yes
Fort ASYNCHRONOUS: yes
Fort PROCEDURE: yes
Fort USE...ONLY: yes
Fort C_FUNLOC: yes
Fort f08 using wrappers: yes
Fort MPI_SIZEOF: yes
C profiling: yes
C++ profiling: no
Fort mpif.h profiling: yes
Fort use mpi profiling: yes
Fort use mpi_f08 prof: yes
C++ exceptions: no
Thread support: posix (MPI_THREAD_MULTIPLE: yes, OPAL support: yes,
OMPI progress: no, ORTE progress: yes, Event lib:
yes)
Sparse Groups: no
Internal debug support: no
MPI interface warnings: yes
MPI parameter check: runtime
Memory profiling support: no
Memory debugging support: no
dl support: yes
Heterogeneous support: no
mpirun default --prefix: yes
MPI_WTIME support: native
Symbol vis. support: yes
Host topology support: yes
IPv6 support: no
MPI1 compatibility: yes
MPI extensions: affinity, cuda, pcollreq
FT Checkpoint support: no (checkpoint thread: no)
C/R Enabled Debugging: no
MPI_MAX_PROCESSOR_NAME: 256
MPI_MAX_ERROR_STRING: 256
MPI_MAX_OBJECT_NAME: 64
MPI_MAX_INFO_KEY: 36
MPI_MAX_INFO_VAL: 256
MPI_MAX_PORT_NAME: 1024
MPI_MAX_DATAREP_STRING: 128
MCA allocator: basic (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA allocator: bucket (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA backtrace: execinfo (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA btl: self (MCA v2.1.0, API v3.1.0, Component v4.1.5)
MCA btl: smcuda (MCA v2.1.0, API v3.1.0, Component v4.1.5)
MCA btl: tcp (MCA v2.1.0, API v3.1.0, Component v4.1.5)
MCA btl: vader (MCA v2.1.0, API v3.1.0, Component v4.1.5)
MCA compress: bzip (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA compress: gzip (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA crs: none (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA dl: dlopen (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA event: libevent2022 (MCA v2.1.0, API v2.0.0, Component
v4.1.5)
MCA hwloc: hwloc201 (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA if: linux_ipv6 (MCA v2.1.0, API v2.0.0, Component
v4.1.5)
MCA if: posix_ipv4 (MCA v2.1.0, API v2.0.0, Component
v4.1.5)
MCA installdirs: env (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA installdirs: config (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA memory: patcher (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA mpool: hugepage (MCA v2.1.0, API v3.0.0, Component v4.1.5)
MCA patcher: overwrite (MCA v2.1.0, API v1.0.0, Component
v4.1.5)
MCA pmix: isolated (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA pmix: pmix3x (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA pstat: linux (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA rcache: grdma (MCA v2.1.0, API v3.3.0, Component v4.1.5)
MCA rcache: gpusm (MCA v2.1.0, API v3.3.0, Component v4.1.5)
MCA rcache: rgpusm (MCA v2.1.0, API v3.3.0, Component v4.1.5)
MCA reachable: weighted (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA shmem: mmap (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA shmem: posix (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA shmem: sysv (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA timer: linux (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA errmgr: default_app (MCA v2.1.0, API v3.0.0, Component
v4.1.5)
MCA errmgr: default_hnp (MCA v2.1.0, API v3.0.0, Component
v4.1.5)
MCA errmgr: default_orted (MCA v2.1.0, API v3.0.0, Component
v4.1.5)
MCA errmgr: default_tool (MCA v2.1.0, API v3.0.0, Component
v4.1.5)
MCA ess: env (MCA v2.1.0, API v3.0.0, Component v4.1.5)
MCA ess: hnp (MCA v2.1.0, API v3.0.0, Component v4.1.5)
MCA ess: pmi (MCA v2.1.0, API v3.0.0, Component v4.1.5)
MCA ess: singleton (MCA v2.1.0, API v3.0.0, Component
v4.1.5)
MCA ess: tool (MCA v2.1.0, API v3.0.0, Component v4.1.5)
MCA ess: slurm (MCA v2.1.0, API v3.0.0, Component v4.1.5)
MCA filem: raw (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA grpcomm: direct (MCA v2.1.0, API v3.0.0, Component v4.1.5)
MCA iof: hnp (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA iof: orted (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA iof: tool (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA odls: default (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA odls: pspawn (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA oob: tcp (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA plm: isolated (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA plm: rsh (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA plm: slurm (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA ras: simulator (MCA v2.1.0, API v2.0.0, Component
v4.1.5)
MCA ras: slurm (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA regx: fwd (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA regx: naive (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA regx: reverse (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA rmaps: mindist (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA rmaps: ppr (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA rmaps: rank_file (MCA v2.1.0, API v2.0.0, Component
v4.1.5)
MCA rmaps: resilient (MCA v2.1.0, API v2.0.0, Component
v4.1.5)
MCA rmaps: round_robin (MCA v2.1.0, API v2.0.0, Component
v4.1.5)
MCA rmaps: seq (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA rml: oob (MCA v2.1.0, API v3.0.0, Component v4.1.5)
MCA routed: binomial (MCA v2.1.0, API v3.0.0, Component v4.1.5)
MCA routed: direct (MCA v2.1.0, API v3.0.0, Component v4.1.5)
MCA routed: radix (MCA v2.1.0, API v3.0.0, Component v4.1.5)
MCA rtc: hwloc (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA schizo: flux (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA schizo: ompi (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA schizo: orte (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA schizo: jsm (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA schizo: slurm (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA state: app (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA state: hnp (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA state: novm (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA state: orted (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA state: tool (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA bml: r2 (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA coll: adapt (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA coll: basic (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA coll: han (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA coll: inter (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA coll: libnbc (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA coll: self (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA coll: sm (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA coll: sync (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA coll: tuned (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA coll: cuda (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA fbtl: posix (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA fcoll: dynamic (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA fcoll: dynamic_gen2 (MCA v2.1.0, API v2.0.0, Component
v4.1.5)
MCA fcoll: individual (MCA v2.1.0, API v2.0.0, Component
v4.1.5)
MCA fcoll: two_phase (MCA v2.1.0, API v2.0.0, Component
v4.1.5)
MCA fcoll: vulcan (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA fs: ufs (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA io: ompio (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA io: romio321 (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA op: avx (MCA v2.1.0, API v1.0.0, Component v4.1.5)
MCA osc: sm (MCA v2.1.0, API v3.0.0, Component v4.1.5)
MCA osc: pt2pt (MCA v2.1.0, API v3.0.0, Component v4.1.5)
MCA osc: rdma (MCA v2.1.0, API v3.0.0, Component v4.1.5)
MCA osc: ucx (MCA v2.1.0, API v3.0.0, Component v4.1.5)
MCA pml: cm (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA pml: ob1 (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA pml: ucx (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA pml: v (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA rte: orte (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA sharedfp: individual (MCA v2.1.0, API v2.0.0, Component
v4.1.5)
MCA sharedfp: lockedfile (MCA v2.1.0, API v2.0.0, Component
v4.1.5)
MCA sharedfp: sm (MCA v2.1.0, API v2.0.0, Component v4.1.5)
MCA topo: basic (MCA v2.1.0, API v2.2.0, Component v4.1.5)
MCA topo: treematch (MCA v2.1.0, API v2.2.0, Component
v4.1.5)
MCA vprotocol: pessimist (MCA v2.1.0, API v2.0.0, Component
v4.1.5)
