open ar0231 camera failed on px2.
I flashed the DriveInstall_4.1.8.0L_SDK_b43.run on our px2 platform. insert the gmsl ar0231 camera into the A0 interface.
And tried following command to lunch camera, here is error log:
root@nvidia:/home/nvidia/vibrante-t186ref-linux/samples/nvmedia/ipp_raw# ./x11/nvmipp_raw -cf e2379a_c01.conf -c dvp-ss3322-rccb-raw12-1920x1208-ab -d 0 --aggregate 1 --nvplugin
receive_from: Timeout Error.
Please check Ethernet ip configuration or
check Aurix firmware version
iscRootDevOpen: Failed to power on camera(s)
NvMediaISCRootDeviceCreate: Unable to open root device
nvmedia: ERROR: Init: Failed to create NvMedia ISC root device
nvmedia: ERROR: IPPInit: Failed to initialize ISC devices
[NvMediaIPPManagerDestroy:189] Bad parameter
nvmedia: ERROR: main: Error in IPPInit
can you help on this?
thanks
xingxing
Dear xingwing,
dvp-ss3322-* is configuration for sekonix SF3322 camera.
Can you please check https://docs.nvidia.com/drive/nvvib_docs/index.html#page/NVIDIA%2520DRIVE%2520Linux%2520SDK%2520Development%2520Guide%2FMultimedia%2Fnvmedia_nvmipp_raw.html%23 for correct command.
Also, if possible could you upgrade to latest PDK(Pease Check https://developer.nvidia.com/nvidia-drive-downloads).
