We have four cameras on tx1 board. Mostly we can open four camera in the same time and it works fine.
But, sometimes we got CSI Timeout error. We are using tegra_multi_media_api to working with NVISP.
The pipi line list as below:
- Open four camera with argus.
- setup 4 VIC to convert the image from camera to RGB.
The resolution output from camera are 2688x1520@30fps.
The error are not always there. Could anyone help figure out what’s the root cause about the “CSI Timeout error”? The issue confused us a long time.
Are there any debug method about such case? we can get more information about the NVISP and its libs.
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 170: Error: Invalid isp config attribute element: "flash.TorchLevel[0]=100.00"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 171: Error: Invalid isp config attribute element: "flash.FlashLevel[0]=180.00"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 180: Error: Invalid isp config attribute: "nr.v1.luma.Enable=TRUE"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 181: Error: Invalid isp config attribute: "nr.v1.luma.IsoThreshold=100"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 182: Error: Invalid isp config attribute: "nr.v1.luma.Slope=0.01"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 183: Error: Invalid isp config attribute: "nr.v1.luma.Threshold=0.015"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 184: Error: Invalid isp config attribute: "nr.v1.chroma.Enable=TRUE"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 185: Error: Invalid isp config attribute: "nr.v1.chroma.IsoThreshold=100"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 186: Error: Invalid isp config attribute: "nr.v1.chroma.Slope=0.40"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 187: Error: Invalid isp config attribute: "nr.v1.chroma.Threshold=0.08"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 188: Error: Invalid isp config attribute: "nr.v2.chroma.Enable=FALSE"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 189: Error: Invalid isp config attribute: "nr.v2.chroma.IsoThreshold=100"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 190: Error: Invalid isp config attribute: "nr.v2.chroma.Slope=1.0"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 191: Error: Invalid isp config attribute: "nr.v2.chroma.Threshold=0.0"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 192: Error: Invalid isp config attribute: "nr.v2.chroma.PredefinedGainResponse={0,0,0,0,0,0,1,2,3,4,4,4,4,4,4,4}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 193: Error: Invalid isp config attribute element: "ae.noiseReduction.Preview[0]={0,0,1,2,2,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 194: Error: Invalid isp config attribute element: "ae.noiseReduction.Preview[1]={0,1,1,2,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 195: Error: Invalid isp config attribute element: "ae.noiseReduction.Preview[2]={1,1,2,2,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 196: Error: Invalid isp config attribute element: "ae.noiseReduction.Preview[3]={2,2,2,3,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 197: Error: Invalid isp config attribute element: "ae.noiseReduction.Still[0]={0,0,1,2,2,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 198: Error: Invalid isp config attribute element: "ae.noiseReduction.Still[1]={0,1,1,2,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 199: Error: Invalid isp config attribute element: "ae.noiseReduction.Still[2]={1,1,2,2,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 200: Error: Invalid isp config attribute element: "ae.noiseReduction.Still[3]={2,2,2,3,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 201: Error: Invalid isp config attribute element: "ae.noiseReduction.Video[0]={0,0,1,2,2,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 202: Error: Invalid isp config attribute element: "ae.noiseReduction.Video[1]={0,1,1,2,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 203: Error: Invalid isp config attribute element: "ae.noiseReduction.Video[2]={1,1,2,2,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 204: Error: Invalid isp config attribute element: "ae.noiseReduction.Video[3]={2,2,2,3,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 205: Error: Invalid isp config attribute: "edgeEnhance.strength.Preview=0.113"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 206: Error: Invalid isp config attribute: "edgeEnhance.strength.Still=0.113"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 207: Error: Invalid isp config attribute: "edgeEnhance.strength.Video=0.113"
NvCameraIspConfigFileLoad: Config file "camera_overrides.isp" Line 455: Error: Invalid isp config attribute element: "mwbCCT.sunlight=6100"
NvCameraIspConfigFileLoad: Config file "camera_overrides.isp" Line 458: Error: Invalid isp config attribute element: "mwbCCT.tungsten=2950"
NvCameraIspConfigFileLoad: Config file "camera_overrides.isp" Line 461: Error: Invalid isp config attribute element: "mwbCCT.flash=7300"
NvCameraIspConfigFileLoad: Config file "camera_overrides.isp" Line 462: Error: Invalid isp config attribute element: "mwbCCT.horizon=3000"
Failed to query video capabilities: Bad address
libv4l2_nvvidconv (1):(765) (INFO) : Allocating (4) OUTPUT PLANE BUFFERS Layout=1
libv4l2_nvvidconv (1):(775) (INFO) : Allocating (4) CAPTURE PLANE BUFFERS Layout=0
libv4l2_nvvidconv (2):(765) (INFO) : Allocating (4) OUTPUT PLANE BUFFERS Layout=1
libv4l2_nvvidconv (2):(775) (INFO) : Allocating (4) CAPTURE PLANE BUFFERS Layout=0
libv4l2_nvvidconv (3):(765) (INFO) : Allocating (4) OUTPUT PLANE BUFFERS Layout=1
libv4l2_nvvidconv (3):(775) (INFO) : Allocating (4) CAPTURE PLANE BUFFERS Layout=0
libv4l2_nvvidconv (4):(765) (INFO) : Allocating (4) OUTPUT PLANE BUFFERS Layout=1
libv4l2_nvvidconv (4):(775) (INFO) : Allocating (4) CAPTURE PLANE BUFFERS Layout=0
Sensor_GetV4LPixelType: pixel type 0x101 invalid
PowerServiceCore:handleRequests: timePassed = 542
PowerServiceCore:handleRequests: timePassed = 453
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
launchCC abort cc 2104
SCF: Error Timeout: (propagating from src/api/Session.cpp, function capture(), line 731)
(Argus) Error Timeout: Failed to submit first capture request (propagating from src/api/CaptureSessionImpl.cpp, function submitCaptureRequests(), line 301)
(Argus) Error Timeout: (propagating from src/api/CaptureSessionImpl.cpp, function threadFunction(), line 741)
launchCC abort cc 1105
Error: waitCsiFrameStart timeout guid 1
Error: waitCsiFrameStart Something went wrong with waiting on frame start
Error: waitCsiFrameEnd timeout guid 1
Error: waitCsiFrameEnd Something went wrong with waiting on csi frame end
Error: waitCsiFrameStart timeout guid 2
Error: waitCsiFrameEnd timeout guid 2
