Hello NVIDIA Support Team,
I would like to request an increase in my free-tier NVIDIA NIM API rate limit for personal, non-commercial open-source development.
Account Email: barkerh4200@gmail.com
Current Limit: 40 RPM
Requested Limit: 200 RPM
Primary Model Used: z-ai/glm-5.2
Use Case: Open-source Minecraft performance optimization, bug fixing, and development tooling.
I am an independent open-source developer working on performance optimizations, stability improvements, and hotfixes for Minecraft 1.20.1 mods and modpacks. My current focus is reducing server/client lag, improving tick performance, diagnosing difficult mod interactions, and developing compatibility and performance patches that can help Minecraft 1.20.1 modpacks run reliably on computers with lower hardware capabilities and without requiring extremely high system specifications.
Some of my current open-source work includes:
DirectMemFix
GitHub repository: barkerh4200-spec / directmemfix
AE2AsyncModelHotFix
GitHub repository: barkerh4200-spec / AE2AsyncModelHotFix
I am also actively working with major open-source Minecraft projects including:
GregTech Modern
GitHub repository: GregTechCEu / GregTech-Modern
Applied Energistics 2
GitHub repository: AppliedEnergistics / Applied-Energistics-2
These repository names can be searched directly on GitHub if additional verification is required.
My development work involves using AI-assisted development to investigate source code, analyze stack traces, identify performance bottlenecks, prototype fixes, and rapidly iterate on optimizations and hotfixes. This frequently requires multiple model requests in parallel, particularly when investigating complex interactions between several Minecraft mods.
Unfortunately, I am currently hitting the 40 RPM NVIDIA NIM rate limit and receiving 429 rate-limit errors during development. These interruptions significantly slow down the investigation and testing cycle, particularly when multiple independent code-analysis tasks need to be performed at the same time.
I am specifically requesting 200 RPM so that I can use NVIDIA NIM to accelerate development of these open-source optimizations and patches. The additional capacity would be used strictly for development of open-source Minecraft-related software, performance improvements, debugging, and hotfixes.
I would also like to explicitly confirm that:
The NVIDIA NIM API key will be used for open-source development only.
I will not use the API key for proprietary or closed-source commercial development.
Optimizations, hotfixes, and other improvements produced through this development work will be released through appropriate open-source repositories and under the relevant open-source licenses.
Where appropriate, I will credit NVIDIA and NVIDIA NIM for providing the additional API capacity that helped facilitate the development and testing of these open-source improvements.
The increased request capacity will be used to accelerate development rather than for commercial API resale or unrelated workloads.
I strongly believe NVIDIA NIM can be particularly valuable for open-source developers working on projects like these, and I would very much like to continue using NVIDIA’s infrastructure to contribute improvements back to the open-source ecosystem.
If possible, I would greatly appreciate increasing my limit from 40 RPM to 200 RPM.
Thank you very much for considering my request and for supporting open-source development through NVIDIA NIM.
Kind regards,
Henry Barker
