Hi everyone,
I’m open-sourcing an evidence-first dual-GB10 / DGX Spark deployment that combines two results:
- MiniMax H3 performance: dual-node SP2 + fused official Turbo8 + SageAttention3 reaches 1.691x end-to-end throughput versus an already optimized single-GB10 Sol-attention + official Turbo8 baseline.
- Qwen3.8 + H3 coexistence: Qwen3.8-27B TP2 keeps its full 262,144-token server context while H3 SP2 remains resident and usable on the same two GB10 systems.
Repository:
Engineering preview release:
Matched H3 performance
All routes used 864x480 / 192 frames / 8.0 s / official Turbo8 / FP8 Transformer, with one cold run and five independent hot seeds:
| Route | Hot median | Throughput vs optimized single GB10 |
| Single GB10, Sol + official Turbo8 | 232.730 s | 1.000x |
| Dual GB10 SP2, dynamic LoRA + FA4 | 168.431 s | 1.382x |
| Dual GB10 SP2, fused LoRA + FA4 | 157.622 s | 1.477x |
| Dual GB10 SP2, fused LoRA + SA3 | 137.607 s | 1.691x |
SA3 adds 14.5% throughput over the mature dual-GB10 fused-FA4 route.
This is intentionally compared against the strongest matched single-node Sol + Turbo8 baseline, not a weak intermediate run. Historical non-Turbo/non-Sol routes were much slower, but their shapes and step counts differed, so I am not advertising a misleading multiplier.
For quality, I generated eight matched FA4/SA3 pairs (16 complete videos) covering faces, hands, fast motion, fabric, water, fine lines, I2VA and FL2VA. In an anonymized, cross-randomized owner review, A/B were generally comparable; no systematic SA3 visual regression was observed in this matrix. SA3 is still approximate, so the FA4 rollback remains part of the design.
Why SA3 needed a GB10-specific fix
The upstream Blackwell kernel used a fixed 170-CTA persistent grid, while GB10 has 48 SMs. The public package includes runtime-SM launch compatibility and credits the related upstream work:
- Fix hardcoded SM count (170) in Blackwell FP4 persistent kernel launch by sowmy86 · Pull Request #379 · thu-ml/SageAttention · GitHub
- sage-attention 3 mosaic artifacts and not faster than sage-attention 2.2 on dgx spark · Issue #321 · thu-ml/SageAttention · GitHub
The final H3 route combines:
- SP2 / Ulysses2 across two GB10 nodes
- H3 packed-varlen SA3 adapter with global mean
- official Turbo8, eight steps
- pruned FP8 Transformer
- one-shot fused FP8 LoRA
- SP2 QKV all-gather
- no pinned CPU memory
- serial fully streamed VAE decode
Qwen3.8 262K + H3 coexistence
The Qwen side is also included and sanitized:
- Qwen3.8-27B NVFP4, TP2, DFlash2, FP8 KV
- 262,144 context, 278,528 max-total-token cap, one running request
- Normal and experimental Creative aliases
- Low default reasoning plus Kimi-style effort mapping
- media-history compaction
- two-node memory collectors and a fail-closed UMA admission governor
The important finding was that the 262K context capacity itself was not the main coexistence failure. The dominant hazards were GB10 unified-memory mapping pressure, pinned host memory, VAE residency/parallel-decode peaks, and overlapping heavy Qwen decode with H3 denoise.
A >241K-token capability probe passed, an ~80K-token overlap canary completed, and a four-shot real-video batch completed without service restart. However, sustained heavy overlap can slow H3 materially. I therefore describe this as an operational coexistence candidate, not a long-duration or 24x7 stability qualification. Long soak, cold-boot recovery and third-party clean-room reconstruction remain open gates.
What is included
- SGLang SP2 patches
- H3 packed-varlen SA3 adapter and runtime-SM fix
- Turbo8 FP8 fusion builder
- matched benchmark data and blind-review tooling
- sanitized Qwen 262K coexistence profile
- Normal/Creative proxy, reasoning mapping and memory governor
- 45 local unit/mock tests plus public GitHub Actions checks
No model weights, official LoRA weights, private host information, videos or prebuilt CUDA wheels are included. Users must obtain model assets separately and follow their licenses.
I would especially appreciate feedback from other DGX Spark owners on:
- clean-room reproduction of the 1.691x route
- SA3 quality across more H3 shapes and workloads
- long-duration Qwen/H3 UMA coexistence
- whether these patches should be upstreamed as smaller PRs
