OpenACC cache directive issues
I have some problems using the OpenACC cache directive with the PGI compiler.
	int iters = 0 ;
#pragma acc data copy(Uold), copyin(rhs), create(Unew)
  while (iters < max_iters && l2_norm > 1e-9) {
    ++iters;
    /* update each interior point */
#pragma acc kernels loop independent
    for (k=1; k<= n; k++){
#pragma acc loop independent
		for (j=1; j<= n; j++){
			for (i=1; i<= n; i++) {
#pragma acc cache(rhs[k-1:k+1][j-1:j+1][i-1:i+1])
//#pragma acc cache(Uold[k-1:k+1][j-1:j+1][i-1:i+1])
	  Unew[k][j][i] = factor*(rhs[k][j][i]
                                  +factor2*(Uold[k][j][i-1]+Uold[k][j][i+1]
					    +Uold[k][j-1][i]+Uold[k][j+1][i]
					    +Uold[k+1][j][i]+Uold[k-1][j][i])
				  +Uold[k-1][j-1][i]+Uold[k-1][j+1][i]
				  +Uold[k-1][j][i-1]+Uold[k-1][j][i+1]
				  +Uold[k][j-1][i-1]+Uold[k][j+1][i-1]
				  +Uold[k][j-1][i+1]+Uold[k][j+1][i+1]
				  +Uold[k+1][j-1][i]+Uold[k+1][j+1][i]
				  +Uold[k+1][j][i-1]+Uold[k+1][j][i+1]);
/* pointer swap */
	REAL*** tmp;
	REAL*** p_old = Uold;
	REAL*** p_new = Unew;
	tmp = p_old; p_old= p_new; p_new = tmp;
	nIters = iters;
If I uncomment the second #pragma acc cache, the compilation outputs
PGC-W-0155-Compiler failed to translate accelerator region (see -Minfo messages): Unexpected load/store type (openacc_poisson.c: 149)
main:
    140, getTime inlined, size=6, file openacc_poisson.c (67)
    144, Generating create(Unew[0:][0:][0:])
         Generating copyin(rhs[0:][0:][0:])
         Generating copy(Uold[0:][0:][0:])
    150, Loop is parallelizable
    152, Loop is parallelizable
    154, Loop is parallelizable
         Accelerator kernel generated
        150, #pragma acc loop vector(4) /* threadIdx.y */
        152, #pragma acc loop gang /* blockIdx.y */
             Cached references to size [(y+2)x3x(x+2)] block of 'rhs'
             Cached references to size [(y+2)x3x(x+2)] block of 'Uold'
        154, #pragma acc loop gang, vector(64) /* blockIdx.x threadIdx.x */
    178, getTime inlined, size=6, file openacc_poisson.c (67)
PGC/x86-64 Linux 13.1-1: compilation completed with warnings
It seems that PGI compiler has a problem with the j+1 in my Uold array. If I remove the loads from Uold[j+1] the compilation works, but of course the program does not execute correctly.
What do you think I should try?
Thank you,
Valeriu
Hi Valeriu,
This is most likely a compiler error. Can you please send a reproducing case to PGI Customer Support (trs@pgroup.com)?
Caching shouldn’t effect correct execution, so this may be caused by something else. Have you tested your program without OpenACC enabled? You’re pointer swapping doesn’t look correct to me since at Uold and Unew, are never swapped.
  • Mat
Hi Mat,
Thanks for the reply. I’ve sent the full example to the Customer Support.
I was saying that if I removed certain computation from my for loops,(i.e. the accesses to the [j+1] components of the Uold array), then the output is wrong because of this algorithmic change.
The pointer swap I think is done correctly,
Best,
Vali
