I have a module that declares types as below:
MODULE ABC
IMPLICIT NONE
TYPE B
INTEGER, ALLOCATABLE, DIMENSION(:,:) :: USA
END TYPE B
TYPE A
INTEGER, ALLOCATABLE, DIMENSION(:,:) :: BRI
TYPE (B), ALLOCATABLE, DIMENSION(:) :: GER
END TYPE A
TYPE (A), ALLOCATABLE, DIMENSION(:) :: TUR
END MODULE MOD_ABC
Then I use this module in a main program and call the derived-data types from device as follows:
!$acc enter data copyin(TUR(1))
!$acc data copyin(FUN(:,:,:),ELFUN(:,:,:,:)) create(NO,I0) copy(PPV(:,:,:))
!$acc parallel loop default(present)
DO NUC = 1,Z
DO EL = K,L
DO J = 1T
NO = TUR(1)%GER(J_P)%USA(EL,J)
I0 = TUR(1)%BRI(NO)
! extra calculations
END DO !J
END DO ! EL
END DO
!$acc end parallel loop
!$acc end data
I included “deepcopy” flag on the Makefile.
When I run this program, it gives the error that
Failing in Thread:1
call to cuStreamSynchronize returned error 700: Illegal address during kernel execution
I looked at the manuals of NVIDIA. Yet I could not understand how to manage derived-data types.
I could not find a whole sample code that shows such an example. I am also open to online recommendations for sample codes.
Thanks for your attention!
