Hi
I read this code in c++ :
int curLevel = 1;
#pragma acc data copyin(dataElement[0:nEdge] , graphIndex[0:noOfNodes]) , create(visited[0:noOfNodes]),create(mask[0:noOfNodes]) ,create(parentDevice[0:noOfNodes]),create(distanceDevice[0:noOfNodes]),create(curIndexDevice[0:noOfNodes])
//start data region
#pragma acc parallel loop independent
for (int i = 0; i < noOfNodes; i++)
visited[i] = false;
mask[i] = false;
parentDevice[i] = -2;
distanceDevice[i] = 0;
curIndexDevice[i] = 0;
//start bfs set clock
visited[source] = true;
distanceDevice[source] = 0;
parentDevice[source] = -1;
//int loopIndex = graphIndex[source + 1] - [graph]
#pragma acc update device(visited[source:1],parentDevice[source:1],distanceDevice[source:1])
/*find neighbours of source and set to new level work set and set curIndex to 1 show level 1*/
for (int i = graphIndex[source]; i < graphIndex[source+1]; i++)
visited[i] = true;
mask[i] = true;
distance[i] = 1;
parent[i] = source;
curIndexDevice[i]=1;
//nodesArray[i].curIndex = 1;
int i, j;
do{
stop = false;
//#pragma acc update device(curLevel)
#pragma acc update device(stop)
#pragma acc parallel loop independent copy(stop , curLevel) //,lastprivate(stop)
for (i = 0; i < noOfNodes; i++)
if (mask[i] && curLevel == curIndexDevice[i]){//if mask node true and cureIndex equal with current level cand be find neighbours
//#pragma acc parallel loop
for (j = graphIndex[i]; j < graphIndex[i + 1]; j++){
//for (j = 0; j < 128; j++){
//int index = nodesArray[i].neighbours[j];
if (!visited[dataElement[j]]){//if visited=true then before find neighbours
mask[dataElement[j]] = true;
visited[dataElement[j]] = true;//go to true
parent[dataElement[j]] = i;
stop = true;
curIndexDevice[dataElement[j]] = curLevel + 1;
distance[dataElement[j]] = distance[i] + 1;
//curIndexDevice[j] = 2;
}// end if
}//end for j
}//end if
}//end parallel for
curLevel++;
//#pragma acc update host(stop)
} while (stop);
}//end data region
//end bfs pause time
And i use this command in pgi 64 windows :
pgcpp -acc -Minfo newbfs.cpp
