I am planning to benefit from the OpenACC data regions, in order to use the cuSPARSE library. However, it can be used in the Host Code. Then I put the subroutines, which are in a module, to the Host Code. Yet, when i compile and run the code it gives the ‘signal 11’. The code works when the subroutines are in a module; when it is not in a module, it crashes. What should I do to work the code?
The Makefile:
FC=nvfortran
TIMER=/usr/bin/time
OPT=
NOPT=-fast -Minfo=opt $(OPT)
abc: abc.o
$(TIMER) ./abc.o $(STEPS) -acc -fopenmp
abc.o: abc.f90
$(FC) -o $@ $< -fopenmp -acc -ta=tesla:cc75 -Minfo=accel
clean:
rm -f *.o *.exe *.s *.mod a.out
The Code:
program main
use omp_lib
implicit none
integer :: nsize, i
real*8, allocatable :: A(:,:), C(:,:), b(:)
real*8 :: k(550), r
real*8 :: start_time, elapsed_time
nsize = 10000
allocate(A(nsize,nsize),C(nsize,nsize))
allocate(b(nsize))
call init_diag_dom_mat(A)
do i = 1, nsize
call random_number(r)
b(i) = mod(r, 51.0d0)
end do
start_time = omp_get_wtime()
!$OMP PARALLEL DO DEFAULT(NONE) &
!$OMP PRIVATE(C,i) NUM_THREADS(10) &
!$OMP SHARED(A,b,nsize,k)
do i = 1,550
k(i) = 0.0d0
C = A*float(i)
call tartar(C, b, nsize, k(i))
enddo
!$OMP END PARALLEL DO
write (*,*) k(1)
elapsed_time = omp_get_wtime() - start_time
write (*,*) elapsed_time, " seconds"
return
end program main
subroutine init_diag_dom_mat(A)
implicit none
real*8, intent(out), dimension(:,:) :: A
integer :: i,j,nsize
real*8 :: sum, x
nsize = ubound(A,1)
do i = 1, nsize
sum = 0
do j = 1, nsize
call random_number(x)
x = mod(x, 23.0d0) / 1000.0d0
A(j,i) = x
sum = sum + x
end do
A(i,i) = A(i,i) + sum
do j = 1, nsize
A(j,i) = A(j,i) / sum
end do
end do
end subroutine
subroutine tartar(A, b, nsize, k)
implicit none
real*8, intent(inout), dimension(:,:) :: A
real*8, intent(in), dimension(:) :: b
real*8, allocatable, dimension(:) :: c,d
real*8, intent(inout):: k
real*8 :: e, f
integer :: i, j, z
integer, value :: nsize
nsize = ubound(A,1)
allocate(c(nsize),d(nsize))
a = 0.0d0
do i = 1, nsize
A(i,i) = A(i,i) + 2.0d0
end do
do i = 1, nsize
A(i,i) = A(i,i)/2.0d0
end do
!$acc data copyin(A(nsize,nsize),b(nsize)) copyout(c(nsize),d(nsize))
!$acc parallel loop gang async
do i = 1, nsize
e = 0.0d0
!$acc loop seq reduction(+:e)
do j = 1,nsize
!$acc loop vector
do z = 1,nsize
e = e + A(i,j)*A(i,z)
end do
end do
c(i) = e
end do
do i = 1, nsize
f = 0.0d0
!$acc loop vector reduction(+:f)
do j = 1,nsize
f = f + A(i,j)*b(j)
end do
d(i) = f
end do
!$acc wait
!$acc end data
end subroutine
The Compilation Error:
nvfortran -o abc.o abc.f90 -fopenmp -acc -ta=tesla:cc75 -Minfo=accel
tartar:
108, Generating copyin(a(:nsize,:nsize),b(:nsize)) [if not already present]
Generating copyout(d(:nsize),c(:nsize)) [if not already present]
109, Generating Tesla code
110, !$acc loop gang ! blockidx%x
113, !$acc loop seq
115, !$acc loop vector(128) ! threadidx%x
Generating reduction(+:e)
115, Loop is parallelizable
124, Generating Tesla code
125, !$acc loop gang ! blockidx%x
128, !$acc loop vector(128) ! threadidx%x
Generating reduction(+:f)
128, Loop is parallelizable
/usr/bin/time ./abc.o -acc -fopenmp
Command terminated by signal 11
0.01user 0.00system 0:00.10elapsed 10%CPU (0avgtext+0avgdata 5600maxresident)k
0inputs+0outputs (0major+296minor)pagefaults 0swaps
make: *** [Makefile:8: abc] Error 139
Thank you for your attention!
