OpenACC Fortran maxval
I was wondering why this code does not work with the pgi compiler.
program minmax
  implicit none
  integer, parameter  :: N=300
  real, allocatable   :: a(:,:,:)
  integer             :: i,j,k
  real                :: maxa
  allocate(a(N,N,N))
  a = 1.0
  !$ACC PARALLEL
  maxa = maxval(a)
  !$ACC END PARALLEL
  print *, maxa
end program minmax
Hi MHUGUES,
This is a case where you want to use the “kernels” rather that “parallel” directive. Maxval gets inlined and includes several loops. Since “kernels” allow the compiler to discover parallelization, it’s able to properly to accelerate the loops.
% cat tst.f90
program minmax
  implicit none
  integer             :: i,j,k
  real                :: maxa
  allocate(a(N,N,N))
  a = 1.0
  !$ACC KERNELS
  maxa = maxval(a)
  !$ACC END kernels
  print *, maxa
end program minmax
% pgf90 tst.f90 -Minfo=accel -acc; a.out
minmax:
      0, Accelerator kernel generated
     15, Generating implicit copyin(a(1:300,1:300,1:300))
     16, Loop is parallelizable
         Accelerator scalar kernel generated
         Generating Tesla code
         16, !$acc loop gang, vector(32) ! blockidx%x threadidx%x
             !$acc loop gang, vector(4) ! blockidx%z threadidx%y
             !$acc loop gang ! blockidx%y
             Generating implicit reduction(max:a$r)
    1.000000
  • Mat
Thanks Matt.
It is working with KERNELS indeed
