OpenACC interoperability with thrust, linking error
I try to use thrust::sort to sort an array of floats that is generated by OpenACC. I found an example that pretty much does what I wanted: https://www.olcf.ornl.gov/tutorials/openacc-interoperability-ii/
I tried it and it works fine with the pgcc compiler. However I use the pgc++ and there I cannot get it to link.
The thrust code is this:
#include <thrust/sort.h>
extern "C" void sort(float *values, int num, void *stream)
    thrust::sort(thrust::cuda::par.on((cudaStream_t)stream),
                            values, values + num);
compiled with “nvcc sortgpu.cu -c” (cuda-10.0)
the openacc code is here:
#include <iostream>
#include <openacc.h>
void sort(float *values, int num, void *stream);
int main(int argc, char* argv[])
    int N = 13;
    float *a = new float[N];
    void* stream = acc_get_cuda_stream(acc_async_sync);
    #pragma acc enter data create(a[0:N])
    #pragma acc parallel loop present(a)
    for(int i = 0; i < N; ++i)
        a[i] = (N/2-i)*(N/2-i);
    #pragma acc data present(a)
    #pragma acc host_data use_device(a)
        sort(a, N, stream);
    #pragma acc update host(a[0:N])
        std::cout << a[i] <<"\n";
compiling with: pgc++ -acc -ta=tesla:cuda10.0 -Mcuda=cuda10.0 test_thrust2.cpp sortGPU.o -Minline
and get the error “undefined reference to `sort(float*, int, void*)’”
(sorry for the double post, I couldnt post all at once due to some strange error).
Hi Rob,
The problem is because you’re using extern “C” inconsistently. By default, C++ will name-mangle symbol names but use C-style symbol names when extern “C” is used. Here “sort” gets name-mangled when compiling test_thrust2.cpp but not in sortgpu.cu. Hence the linker can’t match-up the symbol names.
The solution is to either remove extern “C” from sortgpu.cu, or add it to sort’s prototype in test_thrust2.cpp so the symbol naming is consistent.
Hope this helps,
Mat
Thanks, that did the trick.
