I have been working on refactoring some OpenACC code, which has involved the use of more C++ lambdas. This led to some surprising runtime errors and (apparent) stack corruption. I believe I have captured the relevant behaviour in the example below.
It appears that when I asynchronously launch a kernel that calls a lambda, the runtime remembers the address of the (stack-allocated, local) lambda and writes to that address at the next synchronisation (#pragma acc wait(0)
) point. In the example, the object has gone out of scope by that point and its (stack) address is now part of buf
Even without the use of alloca
and buf
it is possible to see in a debugger stacktraces like
#0 __c_mcopy (dst=0x7fffffffcd18, src=0x7fff86000000, len=1) at ../../src/map2mcopy.h:35
#1 0x00007fffed6cc68f in __pgi_uacc_move_buffer (dd=0x7fff86000010) at ../../src/move_buffer.c:62
#2 0x00007fffed13afa0 in __pgi_uacc_cuda_drain_down (devnum=1, qq=0, test=0, tag=0) at ../../src/cuda_drain.c:131
#3 0x00007fffed145b40 in __pgi_uacc_cuda_wait (lineno=20, async=0, dindex=1) at ../../src/cuda_wait.c:80
with dst
addresses that are no longer in scope.
In the OpenACC 3.2 spec (l.1242-3) I see
If a C++ lambda is called in a compute region and does not appear in a data clause, then it is treated as if it appears in a copyin clause on the current construct.
But in the example below, adding copyin(lambda)
to the acc kernels
directive removes the error. Also, if I pass -Minfo=accel
then I see
Generating implicit copy(lambda) [if not already present]
Which seems consistent with the problematic behaviour I see, but not with the part of the spec quoted above.
Some other observations:
- I was not able to reproduce the problem using a plain
int
/float
object, or a custom struct; only a lambda. - The lambda is stateless, so it seems unnecessary for there to be any data transfer at all.
- Returning
&lambda
is just to allow the assertions onold_ptr
, it does not affect the behaviour.
I assume that the example can be made shorter, but this serves to illustrate the point.
#include <alloca.h>
#include <cassert>
constexpr int magic_number = 42424242;
constexpr std::size_t block_size = 1000;
void const* launch(double* p) {
auto const lambda = [](double) { return 42.0; };
#pragma acc kernels present(p[0:1]) async(0)
*p = lambda(*p);
return λ
void wait(void const* old_ptr) {
// allocate a big chunk of the stack
int* buf = static_cast<int*>(alloca(block_size * sizeof(int)));
for(auto i = 0; i < block_size; ++i) {
buf[i] = magic_number;
assert(old_ptr >= &buf[0]);
assert(old_ptr < &buf[block_size]);
// the nvhpc runtime will clobber `buf`
#pragma acc wait(0)
assert(buf[i] == magic_number);
int main() {
double p{1.};
#pragma acc enter data copyin(p)
auto* dead_ptr = launch(&p);
wait(dead_ptr);
return 0;
This is compiled with nvc++ -V22.3 -acc -O test.cpp
and produces
$ ./a.out
a.out: test.cpp:24: void wait(const void *): Assertion `buf[i] == magic_number' failed.
Aborted
on my system at optimisation levels up to -O
; there is no error at -O2
(although in the original application, I saw problems with -O2 -g
). I also tried 21.11 and 22.2, and the test fails there too (at -O
This behaviour is surprising, and superficially seems not to match the spec (although I do not claim expertise there!), and led to rather difficult-to-diagnose crashes later in execution. Naïvely it seems that the compiler should know that the captured lambda’s lifetime may have ended before the next synchronisation occurs, but I did not see any diagnostics. It would be great if this could be improved in an upcoming compiler release.
