Hi!
I’m using HelloWorld example from APP SDK 3.0 with your OpenCL compute program(Particles.cl), clBuildProgram return CL_BUILD_PROGRAM_FAILURE on nVidia GeForce GTX 670, but same program correct works on
AMD R7 240, nVidia 8600GT, nVida 210, Intel HD 4000.
I ahhached OpenCL Program and Sample Code with executable:
Also, Code for Particles.cl:
#ifdef cl_khr_gl_sharing
//#pragma OPENCL EXTENSION cl_khr_gl_sharing : enable
#endif
#ifdef cl_amd_printf
#pragma OPENCL EXTENSION cl_amd_printf : enable
#endif
#ifdef cl_apple_gl_sharing
#pragma OPENCL EXTENSION cl_apple_gl_sharing : enable
#endif
#ifdef cl_khr_byte_addressable_store
#pragma OPENCL EXTENSION cl_khr_byte_addressable_store : enable
#endif
#ifdef cl_khr_d3d11_sharing
//#pragma OPENCL EXTENSION cl_khr_d3d11_sharing : enable
#endif
#ifdef cl_khr_global_int32_base_atomics
#pragma OPENCL EXTENSION cl_khr_global_int32_base_atomics : enable
#endif
typedef float3 Vector3D;
typedef float4 Vector4D;
typedef float4 Quaternion;
__attribute__((aligned(4)))
#define USE_SIMD_PARTICLE
// 64 byte
typedef struct Particle {
#ifdef USE_SIMD_PARTICLE
Vector4D position;
#else
float position[3];
#endif
uchar4 colour;
float Width;
float Height;
float angle;
Vector4D direction;
#else
float direction[3];
#endif
float timeAlive;
float velocity;
float totalTimeAlive;
uint particleEmitter;
} Particle;
//#define USE_SIMD_PARTICLE_INSTANCE
// 36 byte
typedef struct ParticleInstanceData {
#ifdef USE_SIMD_PARTICLE_INSTANCE
float4 position;
#else
float position[4];
#endif
uchar4 Color;
float4 SizeAngle;
#else
float SizeAngle[4];
#endif
} ParticleInstanceData;
// 20 byte
typedef struct ParticleSimulationData {
float dt;
int seed;
uint num;
uint maxParticles;
//uint particleVBIndex;
} ParticleSimulationData;
// 16 byte
typedef struct LinearForceData {
Vector4D force;
} LinearForceData;
// 4 byte
typedef struct ScaleData {
float scale;
} ScaleData;
// 32 byte
typedef struct ColourFaderData {
float endRed;
float endGreen;
float endBlue;
float endAlpha;
float red;
float green;
float blue;
float alpha;
} ColourFaderData;
// 16 byte
typedef struct SpiralMotionData {
float startSpeed;
float endSpeed;
float startRadius;
float endRadius;
} SpiralMotionData;
// 20 byte
typedef struct RotationData {
float startAngle;
float endAngle;
float startSpeed;
float endSpeed;
} RotationData;
// 24 byte
typedef struct RandomDirectionData {
float startRandom[3];
float endRandom[3];
} RandomDirectionData;
#define NO_VEC_EMITTER_DATA
// 112 byte
typedef struct EmitterData {
#ifdef NO_VEC_EMITTER_DATA
float Position[3];
float Direction[3];
#else
Vector4D Position;
Vector4D Direction;
#endif
float minVelocity;
float maxVelocity;
float velocity;
float angle;
float minTimeAlive;
float maxTimeAlive;
float timeAlive;
float startTime;
float endTime;
float emitterTime;
float dEmitterTime;
float curTime;
uchar startColour[4];
uchar endColour[4];
//uint numParticles;
//uint numAliveParticles;
//uint particlePerDeltaTime;
float width;
float height;
uint attachToCamera;
uint isRepeat;
} EmitterData;
// 160 byte
typedef struct BoxEmitter {
EmitterData emitterData;
Vector4D xRange;
Vector4D yRange;
Vector4D zRange;
} BoxEmitter;
// 128 byte
typedef struct EllipsoidEmitter {
Vector4D dimension;
} EllipsoidEmitter;
// 132 byte
typedef struct RingEmitter {
float Width;
float Height;
float depth;
float InnerRadius;
float OuterRadius;
} RingEmitter;
typedef EmitterData PointerEmitter;
__constant float TWO_PI = 2 * 3.1415f;
inline int FastRand(__global int* seed)
barrier(CLK_GLOBAL_MEM_FENCE);
return (((*seed = *seed * 214013L + 2531011L) >> 16) & 0x7fff);
inline float rand(__global int* seed)
const int RAND_MAX = 0x7fff;
float t = FastRand(seed) * (1.0f / RAND_MAX);
return t;
inline float Rand(float minVal, float maxVal, __global int* seed)
float t = rand(seed);
//printf((__constant char*)"Rand minVal %f, maxVal %f, t %f\n", minVal, maxVal, t);
return mix(minVal, maxVal, t);
inline float SymmetricRandom(__global int* seed)
return 2.0f * rand(seed);
void DumpParticle(const Particle particle)
__constant char* format = (__constant char *)"Particle width %f height %f pos %f %f %f"
"totalTimeAlive %f timeAlive %f\n";
printf(format, particle.Width, particle.Height, particle.position.x, particle.position.y, particle.position.z, particle.totalTimeAlive, particle.timeAlive);
#else
printf(format, particle.Width, particle.Height, particle.position[0], particle.position[1], particle.position[2], particle.totalTimeAlive, particle.timeAlive);
#endif
void LinearForceAffector(__global Particle* particle, __global LinearForceData* data, __global const ParticleSimulationData* particleSimulationData)
particle->position.xyz += (particle->direction.xyz * data->force.xyz * particleSimulationData->dt);
#else
particle->position[0] += particle->direction[0] * data->force.x * particleSimulationData->dt;
particle->position[1] += particle->direction[1] * data->force.y * particleSimulationData->dt;
particle->position[2] += particle->direction[2] * data->force.y * particleSimulationData->dt;
#endif
void ScaleAffector(__global Particle* particle, __global ScaleData* data, __global const ParticleSimulationData* particleSimulationData)
float scale = data->scale * particleSimulationData->dt;
particle->Width *= scale;
particle->Height *= scale;
uchar ApplyColor(uchar color, float dc, float clampVal)
int dval = (int)(UCHAR_MAX * dc);
int Color = color - dval;
const int MaxVal = UCHAR_MAX;
Color = clamp(Color, 0, MaxVal);
return Color;
void ColourFaderAffector(__global Particle* particle, __global ColourFaderData* data, __global const ParticleSimulationData* particleSimulationData)
if (data->red != 0.0f) {
particle->colour.x = ApplyColor(particle->colour.x, data->red, data->endRed);
if (data->green != 0.0f) {
particle->colour.y = ApplyColor(particle->colour.y, data->green, data->endGreen);
if (data->blue != 0.0f) {
particle->colour.z = ApplyColor(particle->colour.z, data->blue, data->endBlue);
if (data->alpha != 0.0f) {
particle->colour.w = ApplyColor(particle->colour.w, data->alpha, data->endAlpha);
void GetOffset(float radius, float angle, bool* isCos, float* offset)
if (*isCos) {
*offset = radius * sin(angle);
else {
*offset = radius * cos(angle);
*isCos = true;
void SpiralMotionAffector(__global Particle* particle, __global SpiralMotionData* data, __global ParticleSimulationData* particleSimulationData)
float maxCoord = fmax(particle->direction.x, fmax(particle->direction.y, particle->direction.z));
#else
float maxCoord = fmax(particle->direction[0], fmax(particle->direction[1], particle->direction[2]));
#endif
float speed = Rand(data->startSpeed, data->endSpeed, &particleSimulationData->seed);
particle->angle += (speed * particleSimulationData->dt);
bool isCos = false;
float offset = 0.0f;
float radius = Rand(data->startRadius, data->endRadius, &particleSimulationData->seed);
if (maxCoord != particle->direction.x) {
#else
if (maxCoord != particle->direction[0]) {
#endif
GetOffset(radius, particle->angle, &isCos, &offset);
particle->position.x += offset;
#else
particle->position[0] += offset;
#endif
if (maxCoord != particle->direction.z) {
#else
if (maxCoord != particle->direction[2]) {
#endif
particle->position.z += offset;
#else
particle->position[2] += offset;
#endif
if (maxCoord != particle->direction.y) {
#else
if (maxCoord != particle->direction[1]) {
#endif
particle->position.y += offset;
#else
particle->position[1] += offset;
#endif
void RotationAffector(__global Particle* particle, __global RotationData* data, __global ParticleSimulationData* particleSimulationData)
float angle = Rand(data->startAngle, data->endAngle, &particleSimulationData->seed);
particle->angle += (angle * particleSimulationData->dt * speed);
void RandomDirectionAffector(__global Particle* particle, __global RandomDirectionData* data, __global ParticleSimulationData* particleSimulationData)
float3 offset;
offset.x = Rand(data->startRandom[0], data->endRandom[0], &particleSimulationData->seed);
offset.y = Rand(data->startRandom[1], data->endRandom[1], &particleSimulationData->seed);
offset.z = Rand(data->startRandom[2], data->endRandom[2], &particleSimulationData->seed);
//printf((__constant char*)"RandomDirectionAffector offset %f %f %f\n", offset.x, offset.y, offset.z);
particle->direction.xyz += (offset * particleSimulationData->dt);
particle->direction.xyz = normalize(particle->direction.xyz);
#else
particle->direction[0] += (offset.x * particleSimulationData->dt);
particle->direction[1] += (offset.y * particleSimulationData->dt);
particle->direction[2] += (offset.z * particleSimulationData->dt);
#endif
void updateParticleInstanceData(const Particle particle, __global ParticleSimulationData* particleSimulationData, __global ParticleInstanceData* particleInstanceData)
//barrier(CLK_GLOBAL_MEM_FENCE);
//printf((__constant char*)"updateParticleInstanceData\n");
//DumpParticle(particle);
//particleInstanceData->position = (Vector4D)(particle.position.xyz, 1.0f);
//uint particleVBIndex = atomic_inc(&particleSimulationData->particleVBIndex);
//__global ParticleInstanceData* ParticleInstanceData = particleInstanceData + particleVBIndex;
//int iGID = get_global_id(0);
//__global ParticleInstanceData* ParticleInstanceData = particleInstanceData + iGID;
__global ParticleInstanceData* ParticleInstanceData = particleInstanceData;
ParticleInstanceData->position = (float4)(particle.position.xyz, 1.0f);
#else
ParticleInstanceData->position[0] = particle.position.x;
ParticleInstanceData->position[1] = particle.position.y;
ParticleInstanceData->position[2] = particle.position.z;
#endif
#else
ParticleInstanceData->position[0] = particle.position[0];
ParticleInstanceData->position[1] = particle.position[1];
ParticleInstanceData->position[2] = particle.position[2];
#endif
ParticleInstanceData->Color = particle.colour;
ParticleInstanceData->SizeAngle = (Vector4D)(particle.Width, particle.Height, particle.angle, 1.0f);
#else
ParticleInstanceData->SizeAngle[0] = particle.Width;
ParticleInstanceData->SizeAngle[1] = particle.Height;
ParticleInstanceData->SizeAngle[2] = particle.angle;
ParticleInstanceData->SizeAngle[3] = 1.0f;
#endif
inline void UpdateP(__global Particle* particle, float dt)
particle->position.xyz += (particle->direction.xyz * particle->velocity * dt);
#else
float v = particle->velocity * dt;
particle->position[0] += (particle->direction[0] * v);
particle->position[1] += (particle->direction[1] * v);
particle->position[2] += (particle->direction[2] * v);
#endif
particle->totalTimeAlive += dt;
void updateParticles(__global Particle* particles, int affectorType,
__global ColourFaderData* colourData,
__global ScaleData* scaleData,
__global RotationData* rdata,
__global LinearForceData* forceData,
__global RandomDirectionData* rdData,
__global SpiralMotionData* spData,
__global ParticleInstanceData* particleInstanceData,
__global uint* numParticles)
__global Particle* particle = particles;
if (particle->totalTimeAlive < particle->timeAlive) {
switch (affectorType) {
case 0: {
ColourFaderAffector(particle, colourData, particleSimulationData);
break;
case 1: {
ScaleAffector(particle, scaleData, particleSimulationData);
break;
case 2: {
RotationAffector(particle, rdata, particleSimulationData);
break;
case 3: {
LinearForceAffector(particle, forceData, particleSimulationData);
break;
case 4: {
RandomDirectionAffector(particle, rdData, particleSimulationData);
break;
case 6: {
SpiralMotionAffector(particle, spData, particleSimulationData);
break;
//particle->position += (particle->direction.xyz * particle->velocity * particleSimulationData->dt);
// particle->position[0] += (particle->direction[0] * particle->velocity * particleSimulationData->dt);
//particle->position[1] += (particle->direction[1] * particle->velocity * particleSimulationData->dt);
//particle->position[2] += (particle->direction[2] * particle->velocity * particleSimulationData->dt);
//particle->totalTimeAlive += particleSimulationData->dt;
UpdateP(particle, particleSimulationData->dt);
updateParticleInstanceData(*particle, particleSimulationData, particleInstanceData);
else {
particle->particleEmitter = UINT_MAX;
//printf((__constant char*)"particle->totalTimeAlive >= particle->timeAlive");
if (particleSimulationData->num != 0)
--particleSimulationData->num;
//atomic_dec(&particleSimulationData->num);
__kernel void UpdateParticlesOnly(__global Particle* particles, int affectorType,
updateParticles(particles, affectorType, colourData, scaleData, rdata, forceData, rdData, spData, particleSimulationData, particleInstanceData, numParticles);
inline float LengthSq(const Vector3D v)
return v.x * v.x + v.y * v.y + v.z * v.z;
inline static Vector3D Perpendicular(const Vector3D v)
const float fSquareZero = 1e-06f * 1e-06f;
Vector3D perp = cross(v, (Vector3D)(1.0f, 0.0f, 0.0f));
if (LengthSq(perp) < fSquareZero) {
perp = cross(v, (Vector3D)(0.0f, 1.0f, 0.0f));
return perp;
static float3 QuaternionMultiply(const Quaternion q, const Vector3D v)
Vector3D uv = cross(q.xyz, v);
Vector3D uuv = cross(q.xyz, uv);
uv *= (2.0f * q.w);
uuv *= 2.0f;
return v + uv + uuv;
Quaternion CreateFromAxisAngle(const Vector3D v, float angle)
Quaternion q;
angle *= 0.5f;
float w = 0.0f;
float result = sincos(angle, &w);
q.w = w;
q.xyz = v.xyz * result;
q = normalize(q);
return q;
static Vector3D RandomDeviant(const Vector3D v, float angle, __global int* seed)
Vector3D newUp = Perpendicular(v);
Quaternion q;
__private const float TWO_PI = 2.0f * 3.1415f;
q = CreateFromAxisAngle(v, rand(seed) * TWO_PI);
newUp = QuaternionMultiply(q, newUp);
q = CreateFromAxisAngle(newUp, angle);
return QuaternionMultiply(q, v);
void UpdateAngleDirection(__global EmitterData* emitterData, __global int* seed, __global Particle* particle)
if (emitterData->angle) {
float Angle = Rand(0.0f, emitterData->angle, seed);
particle->direction.xyz = RandomDeviant((float3)(emitterData->Direction[0], emitterData->Direction[1], emitterData->Direction[2]),
#else
particle->direction.xyz = RandomDeviant(emitterData->Direction.xyz, emitterData->angle, seed);
#endif
#else
Vector3D v = RandomDeviant(emitterData->Direction.xyz, emitterData->angle, seed);
particle->direction[0] = v.x;
particle->direction[1] = v.y;
particle->direction[2] = v.z;
#endif
else {
particle->direction.xyz = (float3)(emitterData->Direction[0], emitterData->Direction[1], emitterData->Direction[2]);
#else
particle->direction.xyz = emitterData->Direction.xyz;
#endif
#else
particle->direction[0] = emitterData->Direction.x;
particle->direction[1] = emitterData->Direction.y;
particle->direction[2] = emitterData->Direction.z;
#endif
float UpdateVelocityDirection(__global EmitterData* emitterData, __global int* seed)
if (emitterData->minVelocity != emitterData->maxVelocity) {
return Rand(emitterData->minVelocity, emitterData->maxVelocity, seed);
else if (emitterData->minVelocity != 0.0f) {
return emitterData->minVelocity;
else {
return 0.0f;
inline void AtomicAdd(volatile __global float* source, const float operand) {
union {
unsigned int intVal;
float floatVal;
} newVal;
union {
float floatVal;
} prevVal;
do {
prevVal.floatVal = *source;
newVal.floatVal = prevVal.floatVal + operand;
} while (atomic_cmpxchg((volatile __global unsigned int *)source, prevVal.intVal, newVal.intVal) != prevVal.intVal);
bool CheckEmitt(__global EmitterData* emitterData, __global ParticleSimulationData* particleSimulationData)
//printf((__constant char *)"dt %f EmitterData curtime %f startTime %f\n", particleSimulationData->dt, emitterData->curTime, emitterData->startTime);
#if 0
float t = emitterData->curTime - emitterData->startTime;
if (t <= 0.0f) {
//atom_xchg(&emitterData->numParticles, 0);
return false;
//printf((__constant char *)"CheckEmitt emitterData->numParticles %d emitterData->dEmitterTime %f emitterData->emitterTime %f\n",
//emitterData->numParticles, emitterData->dEmitterTime, emitterData->emitterTime);
if (emitterData->dEmitterTime < emitterData->emitterTime) {
return false;
emitterData->dEmitterTime = emitterData->dEmitterTime - emitterData->emitterTime;
//printf((__constant char *)"CheckEmitt emitterData->dEmitterTime %f\n", emitterData->dEmitterTime);
if (emitterData->endTime > 0.0f && t > emitterData->endTime) {
if (emitterData->isRepeat) {
emitterData->curTime = emitterData->curTime - emitterData->startTime;
return false;
#endif
if (particleSimulationData->num > particleSimulationData->maxParticles) {
//printf((__constant char *)"CheckEmitt max particles\n");
// if (!emitterData->startTime) {
// emitterData->curTime = 0.0f;
return false;
//if (emitterData->particlePerDeltaTime + particleSimulationData->num > particleSimulationData->maxParticles) {
// emitterData->numParticles = particleSimulationData->maxParticles - particleSimulationData->num;
//else {
// atom_xchg(&emitterData->numParticles, emitterData->particlePerDeltaTime);
//if (emitterData->isRepeat && emitterData->endTime < 0.0f) {
// emitterData->curTime = emitterData->curTime - emitterData->startTime;
return true;
void UpdateCommonParameters(__global Particle* particle, __global EmitterData* emitterData, __global int* seed)
//particle->direction = UpdateAngleDirection(emitterData, seed);
UpdateAngleDirection(emitterData, seed, particle);
particle->velocity = UpdateVelocityDirection(emitterData, seed);
void InitStartParameters(__global Particle* particle, __global EmitterData* emitter, __global int* seed)
particle->position.xyz = (float3)(emitter->Position[0], emitter->Position[1], emitter->Position[2]);
#else
particle->position.xyz = emitter->Position.xyz;
#endif
#else
particle->position[0] = emitter->Position.x;
particle->position[1] = emitter->Position.y;
particle->position[2] = emitter->Position.z;
#endif
particle->particleEmitter = emitter->particleEmitter;
particle->Width = emitter->width;
particle->Height = emitter->width;
if (emitter->minTimeAlive > 0.0f && emitter->maxTimeAlive > 0.0f) {
particle->timeAlive = Rand(emitter->minTimeAlive, emitter->maxTimeAlive, seed);
else {
particle->timeAlive = emitter->timeAlive;
particle->colour.x = Rand((float)emitter->startColour[0], (float)emitter->endColour[0], seed);
particle->colour.y = Rand((float)emitter->startColour[1], (float)emitter->endColour[1], seed);
particle->colour.z = Rand((float)emitter->startColour[2], (float)emitter->endColour[2], seed);
particle->colour.w = 255;
particle->totalTimeAlive = 0.0f;
//atomic_inc(&emitter->numAliveParticles);
//printf((__constant char *)"InitStartParameters\n");
//DumpParticle(*particle);
bool Update(__global Particle* particle, __global EmitterData* emitterData, __global ParticleSimulationData* particleSimulationData)
if (particle->particleEmitter != UINT_MAX) {
return true;
InitStartParameters(particle, emitterData, &particleSimulationData->seed);
particleSimulationData->num++;
//atomic_inc(&particleSimulationData->num);
//printf((__constant char *)"Update numParticles %d\n", particleSimulationData->num);
return false;
inline void OffsetPos(__global Particle* particle, const Vector3D p)
particle->position.xyz += p;
#else
particle->position[0] += p.x;
particle->position[1] += p.y;
particle->position[2] += p.z;
#endif
bool BoxEmitterEmittParticles(__global Particle* particle, __global BoxEmitter* boxEmitter, __global ParticleSimulationData* particleSimulationData)
if (!CheckEmitt(&boxEmitter->emitterData, particleSimulationData)) {
return false;
if (Update(particle, &boxEmitter->emitterData, particleSimulationData)) {
return true;
float val = SymmetricRandom(&particleSimulationData->seed);
Vector3D xOff = val * boxEmitter->xRange.xyz;
Vector3D yOff = val * boxEmitter->yRange.xyz;
Vector3D zOff = val * boxEmitter->zRange.xyz;
Vector3D p = (xOff + yOff + zOff);// + Direction * dt;l
OffsetPos(particle, p);
UpdateCommonParameters(particle, &boxEmitter->emitterData, &particleSimulationData->seed);
return false;
bool EllipsoidEmitterEmittParticles(__global Particle* particle, __global EllipsoidEmitter* ellpsoidEmitter, __global ParticleSimulationData* particleSimulationData)
if (!CheckEmitt(&ellpsoidEmitter->emitterData, particleSimulationData)) {
return false;
if (Update(particle, &ellpsoidEmitter->emitterData, particleSimulationData)) {
return true;
Vector3D p;
while (true) {
p.x = SymmetricRandom(&particleSimulationData->seed);
p.y = SymmetricRandom(&particleSimulationData->seed);
p.z = SymmetricRandom(&particleSimulationData->seed);
float d = dot(p, p);
if (d <= 1.0f) {
break;
Vector3D pos = particle->position.xyz;
#else
Vector3D pos = (Vector3D)(particle->position[0], particle->position[1], particle->position[2]);
#endif
//particle->position += ellpsoidEmitter->dimension * p;
OffsetPos(particle, ellpsoidEmitter->dimension.xyz * p);
particle->direction.xyz = normalize(particle->position.xyz - pos);
#else
Vector3D dir = normalize((Vector3D)(particle->position[0], particle->position[1], particle->position[2]) - pos);
particle->direction[0] = dir.x;
particle->direction[1] = dir.y;
particle->direction[2] = dir.z;
#endif
particle->velocity = UpdateVelocityDirection(&ellpsoidEmitter->emitterData, &particleSimulationData->seed);
return false;
bool RingEmitterEmittParticles(__global Particle* particle, __global RingEmitter* ringEmitter, __global ParticleSimulationData* particleSimulationData)
if (!CheckEmitt(&ringEmitter->emitterData, particleSimulationData)) {
return false;
if (Update(particle, &ringEmitter->emitterData, particleSimulationData)) {
return true;
float a = Rand(0.0f, TWO_PI, &particleSimulationData->seed);
float z = SymmetricRandom(&particleSimulationData->seed);
float cosa = 0.0f;
float sina = sincos(a, &cosa);
float inRndRadius = sina * Rand(ringEmitter->InnerRadius, 1.0f, &particleSimulationData->seed);
float outRndRadius = cosa * Rand(ringEmitter->OuterRadius, 1.0f, &particleSimulationData->seed);
Vector3D p = (Vector3D)(inRndRadius * ringEmitter->depth, z * ringEmitter->Height, outRndRadius * ringEmitter->Width);
//particle->position += p;
UpdateCommonParameters(particle, &ringEmitter->emitterData, &particleSimulationData->seed);
return false;
bool PointerEmitterEmittParticles(__global Particle* particle, __global PointerEmitter* pointerEmitterData, __global ParticleSimulationData* particleSimulationData)
//__constant char* format = (__constant char *)"PointerEmitterEmittParticles dt %f EmitterData curtime %f startTime %f\n";
//printf(format, particleSimulationData->dt, pointerEmitterData->curTime, pointerEmitterData->startTime);
if (!CheckEmitt(pointerEmitterData, particleSimulationData)) {
return false;
if (Update(particle, pointerEmitterData, particleSimulationData)) {
return true;
//printf((__constant char *)"PointerEmitterEmittParticles\n");
UpdateCommonParameters(particle, pointerEmitterData, &particleSimulationData->seed);
return false;
__kernel void UpdateParticles(__global Particle* particles,
//__global BoxEmitter* boxEmitterData,
//__global EllipsoidEmitter* ellpsoidEmitterData,
//__global RingEmitter* ringEmitterData,
//__global ColourFaderData* colourData,
//__global ScaleData* scaleData,
//__global RotationData* rData,
//__global LinearForceData* forceData,
//__global RandomDirectionData* rdData,
#if 0
printf((__constant char *)"Particle size %d\n", sizeof(Particle));
printf((__constant char *)"ParticleInstanceData size %d\n", sizeof(ParticleInstanceData));
printf((__constant char *)"ParticleSimulationData size %d\n", sizeof(ParticleSimulationData));
printf((__constant char *)"RandomDirectionData size %d\n", sizeof(RandomDirectionData));
printf((__constant char *)"LinearForceData size %d\n", sizeof(LinearForceData));
printf((__constant char *)"ScaleData size %d\n", sizeof(ScaleData));
printf((__constant char *)"RotationData size %d\n", sizeof(RotationData));
printf((__constant char *)"ColourFaderData size %d\n", sizeof(ColourFaderData));
printf((__constant char *)"SpiralMotionData size %d\n", sizeof(SpiralMotionData));
printf((__constant char *)"PointerEmitter size %d\n", sizeof(PointerEmitter));
printf((__constant char *)"RingEmitter size %d\n", sizeof(RingEmitter));
printf((__constant char *)"EllipsoidEmitter size %d\n", sizeof(EllipsoidEmitter));
printf((__constant char *)"BoxEmitter size %d\n", sizeof(BoxEmitter));
#endif
//printf((__constant char *)"PointerEmitter size %d\n", sizeof(*pointerEmitterData)); // 144
//__constant char* format = (__constant char *)"UpdateParticles2 dt %f EmitterData curtime %f startTime %f\n";
// get index into global data array
__global Particle* particle = particles + iGID;
if (PointerEmitterEmittParticles(particle, pointerEmitterData, particleSimulationData)) {
//printf((__constant char*)"particle->totalTimeAlive < particle->timeAlive");
//RandomDirectionAffector(particle, rdData, particleSimulationData);
//ColourFaderAffector(particle, colourData, particleSimulationData);
//RotationAffector(particle, rData, particleSimulationData);
updateParticleInstanceData(*particle, particleSimulationData, particleInstanceData + iGID);
else {
if (particleSimulationData->num != 0) {
//updateParticles2(particle, rdData, particleSimulationData, particleInstanceData + iGID);
//updateParticles3(particle, rotationData, particleSimulationData, particleInstanceData + iGID);
This Driver bug or not ?
I fixed some errors on GTX 570, but on GTX 760 still i have empty log after calling clGetProgramBuildInfo!
Particles.zip (5.11 KB)
HelloWorldOpenCL.zip (101 KB)
