OpenCL crsh
I have write some OpenCL code… but when I call the “Build” method… I got a “memory access violation”…
I’m not sure that it is related to my kernel code , but I put it here :
NB: Is therea way to debug some code on XP today ?
typedef struct
float4 Origin;
float4 Direction;
float Maximum;
int IsShadowRay;
int pad1;
int pad2;
} Ray;
typedef struct
// Collection position and length
int Instances_Index;
int Instances_Length;
int pad1;
int pad2;
} InstanceList;
typedef struct
int Transforms_Index;
int Transforms_Length;
int pad1;
int pad2;
} MovingMatrix4;
typedef struct
int Type;
int InstanceList_Index;
int TriangleMesh_Index;
int pad1;
} PrimitivesList;
typedef struct
// Accelerator
int AcceleratorBVH_Index;
int pad1;
int pad2;
int pad3;
} Geometry;
typedef struct
MovingMatrix4 o2w;
MovingMatrix4 w2o;
Geometry Geometry;
} Instance;
typedef struct
int Points_Index;
int Points_Length;
int Indices_Index;
int Indices_Length;
} TriangleMesh;
typedef struct
float V01;
float V02;
float V03;
float V04;
float V05;
float V06;
float V07;
float V08;
float V09;
float V10;
float V11;
float V12;
float V13;
float V14;
float V15;
float V16;
} Matrix4;
typedef struct
int PrimitivesList_Index;
int Nodes_Index;
int Nodes_Length;
int PrimitivesIds_Index;
int PrimitivesIds_Length;
int pad1;
int pad2;
int pad3;
} Accelerator_BVH;
typedef struct
/// The bounding box’s coordinates
float MinX, MinY, MinZ, MaxX, MaxY, MaxZ;
} AABB;
typedef struct
float Maximum;
int PrimitiveId;
float U;
float V;
int CurrentInstanceId;
int InstanceId;
int pad1;
int pad2;
} IntersectionResult;
typedef struct
AABB BBox;
/// <summary>
/// The index of the sibbling node (next node at the same level).
/// </summary>
int SkipNodeIndex;
/// <summary>
/// The primitive Id.
/// </summary>
/// <remarks>If it is a set (Count > -1) it is the first index in the primitives' ids list (_primitivesIds)</remarks>
int PrimitiveId;
/// <summary>
/// The number of primitives, used when it is a set.
/// </summary>
ushort Count;
ushort pad1;
int pad2;
int pad3;
int pad4;
} BoundingVolume;
typedef struct MITData
float4 InverseDirection;
int IsXNegative;
int IsYNegative;
int IsZNegative;
} MITData;
typedef struct
__global Ray * Rays;
__global IntersectionResult * Intersections;
__global InstanceList * InstancesList;
__global PrimitivesList * PrimitivesList;
__global Instance * Instances;
__global Matrix4 * Matrix4;
__global TriangleMesh * TriangleMeshes;
__global float * Points;
__global int * Indices;
__global Accelerator_BVH * AcceleratorBVHs;
__global BoundingVolume * AcceleratorBVH_Nodes;
__global int * AcceleratorBVH_PrimitivesIds;
} GlobalBuffer;
__constant GlobalBuffer GB;
// Intersects_BoxRay
int Intersects_BoxRay(struct MITData * mitData, float4 origin, float4 direction, global AABB* aabb, float * minHit, float * maxHit)
float tmin, tmax, tymin, tymax, tzmin, tzmax;
if (mitData->IsXNegative)
    tmin = (aabb->MaxX - origin.x) * mitData->InverseDirection.x;
    tmax = (aabb->MinX - origin.x) * mitData->InverseDirection.x;
else
    tmin = (aabb->MinX - origin.x) * mitData->InverseDirection.x;
    tmax = (aabb->MaxX - origin.x) * mitData->InverseDirection.x;
if (mitData->IsYNegative)
    tymin = (aabb->MaxY - origin.y) * mitData->InverseDirection.y;
    tymax = (aabb->MinY - origin.y) * mitData->InverseDirection.y;
else
    tymin = (aabb->MinY - origin.y) * mitData->InverseDirection.y;
    tymax = (aabb->MaxY - origin.y) * mitData->InverseDirection.y;
if (tmin > tymax || tymin > tmax)
    minHit[0] = MAXFLOAT;
    maxHit[0] = MAXFLOAT;
    return 0;
if (tymin > tmin)
    tmin = tymin;
if (tymax < tmax)
    tmax = tymax;
if (mitData->IsZNegative)
    tzmin = (aabb->MaxZ - origin.z) * mitData->InverseDirection.z;
    tzmax = (aabb->MinZ - origin.z) * mitData->InverseDirection.z;
else
    tzmin = (aabb->MinZ - origin.z) * mitData->InverseDirection.z;
    tzmax = (aabb->MaxZ - origin.z) * mitData->InverseDirection.z;
if (tmin > tzmax || tzmin > tmax)
    return 0;
if (tzmin > tmin)
    tmin = tzmin;
if (tzmax < tmax)
    tmax = tzmax;
minHit[0] = tmin;
maxHit[0] = tmax;
return 1;
// Intersects_Primitive_TriangleMesh
int Intersects_Primitive_TriangleMesh(global int * Indices, global float * Points, float4 origin, float4 direction, int primitiveId)
int tri = 3 * primitiveId;
int i1 = 3 * Indices[tri + 0];
int i2 = 3 * Indices[tri + 1];
int i3 = 3 * Indices[tri + 2];
float4 edge0 = (float4)(
            Points[i2 + 0] - Points[i1 + 0],
            Points[i2 + 1] - Points[i1 + 1],
            Points[i2 + 2] - Points[i1 + 2], 0);
float4 edge1 = (float4)(
    Points[i1 + 0] - Points[i3 + 0],
    Points[i1 + 1] - Points[i3 + 1],
    Points[i1 + 2] - Points[i3 + 2], 0);
float4 edge2 = (float4)(
    Points[i1 + 0] - origin.x,
    Points[i1 + 1] - origin.y,
    Points[i1 + 2] - origin.z, 0);
float4 n = cross(edge0, edge1);
float v = dot(direction, n);
float iv = 1.0f / v;
float va = dot(n, edge2);
float t = iv * va;
int GID = get_global_id(0);
if (t <= 0 || t >= GB.Intersections[GID].Maximum)
    return 0;
float4 i = cross(edge2, direction);
float v1 = dot(i, edge1);
float beta = iv * v1;
if (beta < 0)
    return 0;
float v2 = dot(i, edge0);
if ((v1 + v2) * v > v * v)
    return 0;
float gamma = iv * v2;
if (gamma < 0)
    return 0;
GB.Intersections[GID].Maximum = t;
GB.Intersections[GID].U = beta;
GB.Intersections[GID].V = gamma;
GB.Intersections[GID].PrimitiveId = primitiveId;
GB.Intersections[GID].InstanceId = GB.Intersections[GID].CurrentInstanceId;
return 1;
// Accelerator_BVH_TreeTraversal_TriangleMesh_Internal
int Accelerator_BVH_TreeTraversal_TriangleMesh_Internal(
__global BoundingVolume * _nodes,
__global int * primitivesIds,
__global PrimitivesList * primitivesList)
int bvNodeIndex = 0;
// 1 = true, 0 = false
MITData mitData;
mitData.InverseDirection.x = 1.0f / GB.Rays[GID].Direction.x;
mitData.InverseDirection.y = 1.0f / GB.Rays[GID].Direction.y;
mitData.InverseDirection.z = 1.0f / GB.Rays[GID].Direction.z;
if (mitData.InverseDirection.x < 0)
	mitData.IsXNegative = 1;
else
	mitData.IsXNegative = 0;
if (mitData.InverseDirection.y < 0)
	mitData.IsYNegative = 1;
else
	mitData.IsYNegative = 0;
if (mitData.InverseDirection.z < 0)
	mitData.IsZNegative = 1;
else
	mitData.IsZNegative = 0;
// End of the tree
int stopNodeIndex = _nodes[bvNodeIndex].SkipNodeIndex;
int hasIntersection = 0;
while (bvNodeIndex < stopNodeIndex)
    // Do a hit test with the bounding volume.
    // We use the "closest intersection" to check against the BV intersection.
    // If the 'closest intersection' < 'bv intersection' then there is no
    // primitive intersection possible !
    float minHit;
    float maxHit;
    int hacrap = Intersects_BoxRay(&mitData, GB.Rays[GID].Origin, GB.Rays[GID].Direction, &_nodes[bvNodeIndex].BBox, &minHit, &maxHit);
    if (hacrap && minHit <= GB.Rays[GID].Maximum)
        // It is a leaf -> test the primitives
        if (_nodes[bvNodeIndex].PrimitiveId > -1)
            // Contains a simple primitive
            if(_nodes[bvNodeIndex].Count < 1)
				TriangleMesh triangleMesh = GB.TriangleMeshes[primitivesList[0].TriangleMesh_Index];
				if (Intersects_Primitive_TriangleMesh(&GB.Indices[triangleMesh.Indices_Index], &GB.Points[triangleMesh.Points_Index], GB.Rays[GID].Origin, GB.Rays[GID].Direction, _nodes[bvNodeIndex].PrimitiveId))
                    // If shadow ray
                    if (GB.Rays[GID].IsShadowRay)
                        return 1;
                    hasIntersection = 1;
            // Contains a set of primitive
            else if (_nodes[bvNodeIndex].Count > 0)
                //Note : bv variable not defined
                int startIndex = _nodes[bvNodeIndex].PrimitiveId;
                int endIndex = startIndex + _nodes[bvNodeIndex].Count - 1;
                for (int index = startIndex; index <= endIndex; index++)
					TriangleMesh triangleMesh = GB.TriangleMeshes[primitivesList->TriangleMesh_Index];
					if (Intersects_Primitive_TriangleMesh(&GB.Indices[triangleMesh.Indices_Index], &GB.Points[triangleMesh.Points_Index], GB.Rays[GID].Origin, GB.Rays[GID].Direction, primitivesIds[index]))
						// If shadow ray
							return 1;
        // Next node at the same level OR
        // the next sibbling of the parent.
        bvNodeIndex++;
        if ((bvNodeIndex >= stopNodeIndex || bvNodeIndex == _nodes[bvNodeIndex].SkipNodeIndex) &&
            hasIntersection)
            return 1;
    // Continue at the same level
    else
        bvNodeIndex = _nodes[bvNodeIndex].SkipNodeIndex;
return hasIntersection;
int Accelerator_BVH_TreeTraversal_TriangleMesh(__global Accelerator_BVH * _acceleratorBVHs)
//if (_acceleratorBVHs->Nodes_Index >= 84951)
// return 0;
//if (GB.PrimitivesList[_acceleratorBVHs->PrimitivesList_Index].TriangleMesh_Index < 0)
//	return 0;
return Accelerator_BVH_TreeTraversal_TriangleMesh_Internal(
					&GB.AcceleratorBVH_Nodes[_acceleratorBVHs->Nodes_Index],
					&GB.AcceleratorBVH_PrimitivesIds[_acceleratorBVHs->PrimitivesIds_Index],
					&GB.PrimitivesList[_acceleratorBVHs->PrimitivesList_Index]);
// Intersects_Primitive_Geometry
int Intersects_Primitive_Geometry(Geometry geometry, float4 origin, float4 direction)
if (geometry.AcceleratorBVH_Index < 0)
return 0;
return Accelerator_BVH_TreeTraversal_TriangleMesh( &GB.AcceleratorBVHs[geometry.AcceleratorBVH_Index] );
// Intersects_Instance
int Intersects_Instance(__global Instance * instance, int primitiveId, float4 origin, float4 direction)
GB.Intersections[GID].CurrentInstanceId = primitiveId;
return Intersects_Primitive_Geometry(instance->Geometry, origin, direction);
        // Project the ray to the object space
        Matrix4 transform = w2o.Sample(intersection.Time);
        Ray localRay = ray.Transform(ref transform);
        intersection.Current = this;
        // Test the intersection with the geometry
        bool hasIntersection = Geometry.Intersect(localRay, intersection);
        // FIXME: transfer max distance to current ray
        ray.Maximum = localRay.Maximum;
// Intersects_InstanceList
int Intersects_InstanceList(__global InstanceList * instanceList, float4 origin, float4 direction, int primitiveId)
// 6 2 4 7 3
/if (primitiveId == 7)
GB.Intersections[get_global_id(0)].InstanceId = primitiveId;
GB.Intersections[get_global_id(0)].Maximum = 324.940979f;
GB.Intersections[get_global_id(0)].PrimitiveId = primitiveId;
GB.Intersections[get_global_id(0)].U = 0.15913143f;
GB.Intersections[get_global_id(0)].V = 0.7451545616f;
return 1;
return 0;
if (primitiveId < instanceList->Instances_Length)
	__global Instance * instance = &GB.Instances[(instanceList->Instances_Index + primitiveId)];
	return Intersects_Instance(instance, primitiveId, origin, direction);
return 0;
//if (primitiveId < Instances.Length)
//	return Instances[primitiveId].Intersect(r, state);
//return _lights[primitiveId - Instances.Length].Intersect(r, state);
// Accelerator_BVH_TreeTraversal_InstanceList_Internal
int Accelerator_BVH_TreeTraversal_InstanceList_Internal(
MITData mitData;
else
else
else
// End of the tree
    float minHit;
    float maxHit;
            	// Instance List
				__global InstanceList * instanceList = &GB.InstancesList[primitivesList->InstanceList_Index];
                if(Intersects_InstanceList(instanceList, GB.Rays[GID].Origin, GB.Rays[GID].Direction, _nodes[bvNodeIndex].PrimitiveId))
                    // If shadow ray
                        return 1;
                    //if (hitsCache != null)
                    // hitsCache.AddHit(_nodes[bvNodeIndex].PrimitiveId, ray.Maximum);
					if(Intersects_InstanceList(instanceList, GB.Rays[GID].Origin, GB.Rays[GID].Direction, primitivesIds[index]))
						// If shadow ray
							return 1;
						// hitsCache.AddHit(_primitivesIds[index], ray.Maximum);
        bvNodeIndex++;
            hasIntersection)
            return 1;
    else
// Accelerator_NoAcceleration
void Accelerator_NoAcceleration(__global int * primitivesIds)
int Accelerator_BVH_TreeTraversal_InstanceList(__global Accelerator_BVH * _acceleratorBVHs)
return Accelerator_BVH_TreeTraversal_InstanceList_Internal(
// Trace
__kernel void Trace(
__global Ray * _rays,
__global IntersectionResult * _intersections,
int _rootAcceleratorIndex,
__global InstanceList * _instancesList,
__global PrimitivesList * _primitivesList,
__global Instance * _instances,
__global Matrix4 * _matrix4,
__global TriangleMesh * _triangleMeshes,
__global float * _points,
__global int * _indices,
__global Accelerator_BVH * _acceleratorBVHs,
__global BoundingVolume * _acceleratorBVH_Nodes,
__global int * _acceleratorBVH_PrimitivesIds
GB.Rays = _rays;
GB.Intersections = _intersections;
GB.InstancesList = _instancesList;
GB.PrimitivesList = _primitivesList;
GB.Instances = _instances;
GB.Matrix4 = _matrix4;
GB.TriangleMeshes = _triangleMeshes;
GB.Points = _points;
GB.Indices = _indices;
GB.AcceleratorBVHs = _acceleratorBVHs;
GB.AcceleratorBVH_Nodes = _acceleratorBVH_Nodes;
GB.AcceleratorBVH_PrimitivesIds = _acceleratorBVH_PrimitivesIds;
// Global accelerator ... always a bvh
Accelerator_BVH_TreeTraversal_InstanceList(&GB.AcceleratorBVHs[_rootAcceleratorIndex]);
/*GB.Intersections[get_global_id(0)].InstanceId = 0;
GB.Intersections[get_global_id(0)].Maximum = 100;
GB.Intersections[get_global_id(0)].PrimitiveId = 0;*/
I have the same problem, did you solve it?
