Hi, I am running a kernel doing some operations on two double arrays.
This kernel takes as input the following parameters:
__global const double *pFirstInputArray (number of elements = 20097000), double4 a, double4 b,
int4 c, double4 d, double4 e, double4 f, double4 g, int4 h, double4 i, int l,
__global const double4 *pSecondInputArray (number of elements = 12)
and as output: __global double *pOutputArray (number of elements = 4838400).
If I don’t use one of the double4 parameters (e.g. the parameter f) without setting it to the kernel, the kernel works fine, otherwise no. Am I exceeding the memory capability? Why I have no errors from OpenCL?
