OpenCL performance issues
I’m having the same performance issue with my two programs. One of the programs is a bit more complicated with multiple kernels running in a loop, while the other one is just some writes, a kernel execution followed by some reads.
The problem is that performance go down to as much as 10 times the normal performance when nothing else is using the GPU. It sounds weird, but I need to play a movie or browse a site with a flash ad or something like that for best performance :)
OS: WinXP
Graphics Card: GeForce 8800 GTS
Driver: 195.39
On Windows 7 the performance is stable and good, I don’t know if that’s just because screen rendering is hardware accelerated there or if it’s something else.
Using the OpenCL profiler doesn’t give much, GPU times are the same while the CPU times vary a lot and are much higher.
Below is the part of code executing the simpler kernel.
ciErr1 = clEnqueueWriteBuffer(cqCommandQueue, cmDevVertices0, CL_FALSE, 0, sizeof(cl_float4) * szGlobalWorkSize, vertices0, 0, NULL, NULL);
  ciErr1 |= clEnqueueWriteBuffer(cqCommandQueue, cmDevVertices1, CL_FALSE, 0, sizeof(cl_float4) * szGlobalWorkSize, vertices1, 0, NULL, NULL);
  ciErr1 |= clEnqueueWriteBuffer(cqCommandQueue, cmDevVertices2, CL_FALSE, 0, sizeof(cl_float4) * szGlobalWorkSize, vertices2, 0, NULL, NULL);
  ciErr1 |= clEnqueueWriteBuffer(cqCommandQueue, cmDevTransform0, CL_FALSE, 0, sizeof(cl_float16), &clTransform1, 0, NULL, NULL);
  ciErr1 |= clEnqueueWriteBuffer(cqCommandQueue, cmDevTransform1, CL_FALSE, 0, sizeof(cl_float16), &clTransform2, 0, NULL, NULL);
  if (ciErr1 != CL_SUCCESS)
	printf("Error in clEnqueueWriteBuffer, Line %u in file %s !!!\n\n", __LINE__, __FILE__);
	//Cleanup(EXIT_FAILURE);
	exit(1);
const size_t localWorkSize = LOCAL_WORK_SIZE;
  ciErr1 = clEnqueueNDRangeKernel(cqCommandQueue, ckKernel, 1, NULL, &szGlobalWorkSize, &localWorkSize, 0, NULL, NULL);
  clFinish(cqCommandQueue);
	printf("Error in clEnqueueNDRangeKernel, Line %u in file %s !!!\n\n", __LINE__, __FILE__);
	exit(1);
ciErr1 = clEnqueueReadBuffer(cqCommandQueue, cmDevResultPoints, CL_FALSE, 0, sizeof(cl_float4) * szGlobalWorkSize, contactPoints, 0, NULL, NULL);
  ciErr1 |= clEnqueueReadBuffer(cqCommandQueue, cmDevResultNormals, CL_FALSE, 0, sizeof(cl_float4) * szGlobalWorkSize, contactNormals, 0, NULL, NULL);
  ciErr1 |= clEnqueueReadBuffer(cqCommandQueue, cmDevResultDepths, CL_TRUE, 0, sizeof(cl_float) * szGlobalWorkSize, contactDepths, 0, NULL, NULL);
	printf("Error in clEnqueueReadBuffer, Line %u in file %s !!!\n\n", __LINE__, __FILE__);
	exit(1);
Is this on a laptop system? It could be power-management down-clocking the GPU.
No it’s a stationary computer. It might still be some kind of power-management in BIOS, I’ll have to check that out tomorrow.
I’ve seen significant performance improvements (2x) by “warming up” the card and this is the high-end Tesla C1060 card. I.e. the second time my kernel runs it almost always achieves better performance. Apparently the G80 series did a lot to improve idle power consumption, but maybe at the cost to getting calculations to run fast from a cold start.
Yes I’ve heard about warming up the kernels. However, in one of my programs I have about 10 kernels executed in a row, and the CPU time taken shown in the profiler along with the big overall performance drop suggests it goes to rest between every kernel, which seems just weird. I then continue executing the 10 kernels in a row about 60 times per second or as fast as possible, and the performance decrease is still there.
By the way, nothing found on power saving in BIOS I’m afraid.
how are you checking your times ? did u try the visual profiler ? to get actual gpu run times …
