OpenCL - runs ok except the first calls to clGetPlatformIDs
Hello All,
I have code, multi-threaded, each thread using GPUs:
it loops over:
  • get data
  • spawn : each thread treat data, running 2 subtasks on GPUs,
  • join.
    It works fine, and I get good performance.
Except that the firsts calls to clGetPlatformIDs returns -1001, the code having an alternative code running on CPUs, it executes the first subtasks on CPUs, which increase the overall elapse time.
Any idea why ?
Claude
Is this in Linux? Try enabling persistance mode via nvidia-smi if so.
This error is often associated with OpenCL not finding the correct library in Linux:
http://stackoverflow.com/questions/20335579/error-clgetplatformids-1001-when-running-opencl-code-linux
Yes this is Linux. No problem with library.
I have the same problem with Xeon Phi, I finally solved it by making one call
to clGetPlatformIDs, at the beginning of the main, before starting the threads,
which then redo it without error.
Looks like it needs a “wake up”.
Claude
