Hello everyone,
I am OpenCL learner, and now i want to process the YUV data (format 4:1:1,planar) with le full search Motion Estimation algorithms. The test video is CITY.yuv (size: 352 x 288).
I know that how to process one frame or image in one CommandQueue, but i don’t konw how to process the frame sequence with OpenCL.
As i do, i try to use one for-loop to deal with all the frames in one video, the codes are as follows:
// Core sequence... copy input data to GPU, compute, copy results back
//suppose there is 100 frames.
for(num=0;num<1000;num++)
int i,j;
//Read and Copy pixel data into frame_original
fseek(fp_cur,XX*YY*3/2*(num+1),SEEK_SET);
if(fread(current_frame[0],XX*YY,1,fp_cur)==0)break;
memcpy(frame_original, current_frame[0], width * height * sizeof(cl_uchar));
//Read and Copy pixel data into frame_ref
fseek(fp_ref,XX*YY*3/2*(num+0),SEEK_SET);
if(fread(ref_frame[0],XX*YY,1,fp_ref)==0)break;
memcpy(frame_ref, ref_frame[0], width * height * sizeof(cl_uchar));
// Asynchronous write of data to GPU device
ciErrNum = clEnqueueWriteBuffer(cqCommandQue, cm_original , CL_TRUE, 0, width*height*sizeof(cl_uchar), frame_original, 0, NULL, &H2D);
shrCheckErrorEX (ciErrNum, CL_SUCCESS, pCleanup);
ciErrNum = clEnqueueWriteBuffer(cqCommandQue, cm_ref , CL_FALSE, 0, width*height*sizeof(cl_uchar), frame_ref, 0, NULL, NULL);
//Create the kernel
ckKernel = clCreateKernel(cpProgram,"motion_estimation", &ciErrNum);
// set the global size for each block in frame.
global[0]= width/block_size;
global[1]= height/block_size;
// set the kernel arguments
int n = 0;
printf("clSetKernelArg...\n\n");
ciErrNum = clSetKernelArg(ckKernel, n++, sizeof(cl_mem), (void*)&cm_original);
ciErrNum |= clSetKernelArg(ckKernel, n++, sizeof(cl_mem), (void*)&cm_ref);
ciErrNum |= clSetKernelArg(ckKernel, n++, sizeof(cl_int), (void*)&cm_mv_output);
// Launch kernel
ciErrNum = clEnqueueNDRangeKernel(cqCommandQue, ckKernel, 2, NULL,global,NULL,0, NULL, &ceEvent);
// wait for the command to finish
clFinish(cqCommandQue);
// Read back results and check accumulated
ciErrNum = clEnqueueReadBuffer(cqCommandQue, cm_mv_output, CL_TRUE, 0, X*Y*sizeof(MV), MV_output, 0, NULL, &GPUDone);
but, everytime i debug my code,
there is Unhandled exception at 0x1002f9ba in xxx.exe: 0xC0000005: Access violation reading location 0x00000004 at this line:
I konw that there must be a better way to process the yuv data, if you have any idea or opinion, please let me konw.
Thanks for your help.
