OpenCV 2.4.9 and CUDA 6.0: cuda.h: No such file or directory
When trying to compile OpenCV 2.4.9 with CUDA 6.0 support, I get the following error:
fatal error: cuda.h: No such file or directory
CUDA 6.0 seems to be running fine, nvcc works and the samples too.
There is still an instance of CUDA5.5 on my computer. With that version I did not get nvcc to run, however it worked with OpenCV. Upon closer inspection it seems this instance does have cuda.h, located in /usr/local/cuda-5.5/include.
cuda.h is missing in /usr/local/cuda-6.0/include though. I tried hacking around it by simply copying cuda.h from /usr/local/cuda-5.5/include to /usr/local/cuda-6.0/include. This worked, however the next error I got was:
cufft.h: No such file or directory
This file too I copied from /usr/local/cuda-5.5/include to /usr/local/cuda-6.0/include. This also solved the error, but I do not think this is the way to go.
So I am left wondering what’s wrong. I take it /usr/local/cuda-6.0/include is supposed to contain those header files right? If so, does that mean something went wrong with the installation of CUDA?
Any help is much appreciated!
