Has anyone successfully installed OpenCV 3.2.0 with extra modules (opencv_contrib) on TX2? I cannot get it to build sfm and tracking modules.
outtake from cmake:
– Glog: YES
– Module opencv_sfm disabled because the following dependencies are not found: Glog/Gflags
– Module opencv_tracking disabled because opencv_dnn dependency can’t be resolved!
I installed glog and gflags with:
sudo apt-get install libgflags-dev libgoogle-glog-dev
I am also building this and hit same error. Does this installation only fail on tegra? If it is a problem specific to opencv, please also file a question in opencv forum.
Installation does not fail, but it does not build these 2 modules. This happens only on TX2. Both JetPack3.0 and 3.1. Ok, i will file a question there.
Hi
I manually modified the files in module TRACK to exclude goturnTracker which using “opencv-dnn”, then I can build track-module without “GOTURN tracking algorathm”.
If that does not work i can try to help some more, because i did solve the problem, but i had a bit different software. You could get a protobuf error.
