Opencv 3.4.4 Error
Hello Everyone.
I am running a code for detection of a aurco marker in C++. It is able to compile properly but when I run the code it comes the following error:(Project: 23857): GStreamer -CRITICAL **: gst_element_get_state: assertion ‘GST_ELEMENT (element)’ failed.
VIDEOIO ERROR: V4L: can’t open camera by index 1.
In addition to it, I tried using index as 0 but still, I am not able to open the camera of Jetson board. But, I checked the camera is working using the camera :nvgstcapture.
I will be grateful for the solution.
Onboard camera should use nvarguscamerasrc(or nvcamerasrc). Please refer to
[url]https://devtalk.nvidia.com/default/topic/1024245/jetson-tx2/opencv-3-3-and-integrated-camera-problems-/post/5210735/#5210735[/url]
[url]https://devtalk.nvidia.com/default/topic/987537/videocapture-fails-to-open-onboard-camera-l4t-24-2-1-opencv-3-1/[/url]
The examples run nvcamerasrc, which is deprecated in r32 release. Please use nvarguscamerasrc instead.
Thanks for your advise.It works the camera now.!
