Opencv : 4.1.1 Recode installation
opencv:4.1.1 Encode and install again, which default modules should CMake configure
example:
cmake -D CMAKE_BUILD_TYPE=RELEASE
-D CMAKE_INSTALL_PREFIX=/usr/local
-D INSTALL_PYTHON_EXAMPLES=ON
-D OPENCV_EXTRA_MODULES_PATH=/home/liujinsong/1212opencvmodule/opencv_contrib/modules
-D BUILD_EXAMPLES=ON …
I need a default configuration!!!
By default there is OpenCV package you can install through SDKManager.
If you like to manually build it, please try the script:
https://github.com/AastaNV/JEP/blob/master/script/install_opencv4.6.0_Jetson.sh
This is my environment:
Jetpack 4.6.1
Can I set the default configuration according to my environment
‘Tracker’ is not a member of ‘cv’
cv::Ptrcv::Tracker tracker = cv::TrackerKCF::create();
why ‘Tracker’ is not a member of ‘cv’
