Opencv 4.2.0 Configuration for Jetson Nano Orin 5.1.3 SDKn
Hello, I am trying to install OpenCV 4.2.0 in my Jetson Nano Orin. I used this method.. However, it is not working for OpenCV 4.2.0.
I tried to use following configuration
cmake \
 -D WITH_CUDA=ON \
 -D WITH_CUDNN=ON \
 -D CUDA_ARCH_BIN="7.2,8.7" \
 -D CUDA_ARCH_PTX="" \
 -D OPENCV_GENERATE_PKGCONFIG=ON \
 -D OPENCV_EXTRA_MODULES_PATH=../../opencv_contrib-${version}/modules \
 -D WITH_GSTREAMER=ON \
 -D WITH_LIBV4L=ON \
 -D BUILD_opencv_python3=ON \
 -D BUILD_TESTS=OFF \
 -D BUILD_PERF_TESTS=OFF \
 -D BUILD_EXAMPLES=OFF \
 -D CMAKE_BUILD_TYPE=RELEASE \
 -D CMAKE_INSTALL_PREFIX=/usr/local ..
Can you suggest me configuration which will be suitable for OpenCV 4.2.0 in Jetson Nano Orin (SDK Version 5.1.3). I am OK if CUDA cannot be configured. Thank you.
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Does OpenCV 4.6 work for you?
Since v4.2 was released in 2019, it might not be able to run with CUDA 11.4 and JetPack 5 (Ubuntu 20.04) environment
