hey,
I am trying to use opencv and cuda together on a jetson TX1. I have opencv 3.4.1 with CUDA support.
but I got that error :
OpenCV(3.4.1-dev) Error: The function/feature is not implemented (The called functionality is disabled for current build or platform) in throw_no_cuda, file /home/nvidia/devel/opencv/opencv/modules/core/include/opencv2/core/private.cuda.hpp, line 111
terminate called after throwing an instance of 'cv::Exception'
what(): OpenCV(3.4.1-dev) /home/nvidia/devel/opencv/opencv/modules/core/include/opencv2/core/private.cuda.hpp:111: error: (-213) The called functionality is disabled for current build or platform in function throw_no_cuda
Aborted
here the code taken from opencv example :
#include <iostream>
#include "opencv2/opencv_modules.hpp"
#if defined(HAVE_OPENCV_CUDACODEC)
#include <string>
#include <vector>
#include <algorithm>
#include <numeric>
#include <opencv2/core.hpp>
#include <opencv2/core/opengl.hpp>
#include <opencv2/cudacodec.hpp>
#include <opencv2/highgui.hpp>
#include <opencv2/cudaimgproc.hpp>
int main(int argc, const char* argv[])
const std::string fname = "rtsp://192.168.5.122:8554/ch1";
// const std::string fname = "/home/vbellet/dev/sportview/videos/TheBourne.mp4";
std::cout << cv::getBuildInformation() << std::endl;
cv::namedWindow("CPU", cv::WINDOW_NORMAL);
cv::namedWindow("GPU", cv::WINDOW_OPENGL);
cv::cuda::setGlDevice();
cv::Mat frame;
cv::VideoCapture reader(fname);
cv::cuda::GpuMat d_frame;
cv::Ptr<cv::cudacodec::VideoReader> d_reader = cv::cudacodec::createVideoReader(fname);
cv::TickMeter tm;
std::vector<double> cpu_times;
std::vector<double> gpu_times;
int gpu_frame_count=0, cpu_frame_count=0;
for (;;)
tm.reset(); tm.start();
if (!reader.read(frame))
break;
tm.stop();
cpu_times.push_back(tm.getTimeMilli());
cpu_frame_count++;
cv::imshow("CPU", frame);
if (cv::waitKey(3) > 0)
break;
for (;;)
if (!d_reader->nextFrame(d_frame))
break;
tm.stop();
gpu_times.push_back(tm.getTimeMilli());
gpu_frame_count++;
cv::imshow("GPU", d_frame);
break;
if (!cpu_times.empty() && !gpu_times.empty())
std::cout << std::endl << "Results:" << std::endl;
std::sort(cpu_times.begin(), cpu_times.end());
std::sort(gpu_times.begin(), gpu_times.end());
double cpu_avg = std::accumulate(cpu_times.begin(), cpu_times.end(), 0.0) / cpu_times.size();
double gpu_avg = std::accumulate(gpu_times.begin(), gpu_times.end(), 0.0) / gpu_times.size();
std::cout << "CPU : Avg : " << cpu_avg << " ms FPS : " << 1000.0 / cpu_avg << " Frames " << cpu_frame_count << std::endl;
std::cout << "GPU : Avg : " << gpu_avg << " ms FPS : " << 1000.0 / gpu_avg << " Frames " << gpu_frame_count << std::endl;
return 0;
#else
int main()
std::cout << "OpenCV was built without CUDA Video decoding support\n" << std::endl;
return 0;
#endif
and here the opencv configuration:
General configuration for OpenCV 3.4.1-dev =====================================
Version control: 3.4.1-9-gec0bb66-dirty
Platform:
Timestamp: 2018-11-01T15:00:09Z
Host: Linux 4.4.38-tegra aarch64
CMake: 3.5.1
CMake generator: Unix Makefiles
CMake build tool: /usr/bin/make
Configuration: RELEASE
CPU/HW features:
Baseline: NEON FP16
required: NEON
disabled: VFPV3
C/C++:
Built as dynamic libs?: YES
C++ Compiler: /usr/bin/c++ (ver 5.4.0)
C++ flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG
C++ flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG
C Compiler: /usr/bin/cc
C flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG
C flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG
Linker flags (Release):
Linker flags (Debug):
ccache: NO
Precompiled headers: YES
Extra dependencies: dl m pthread rt /usr/lib/aarch64-linux-gnu/libGLU.so /usr/lib/aarch64-linux-gnu/libGL.so cudart nppc nppial nppicc nppicom nppidei nppif nppig nppim nppist nppisu nppitc npps cublas cufft -L/usr/local/cuda-9.0/lib64
3rdparty dependencies:
OpenCV modules:
To be built: calib3d core cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev dnn features2d flann highgui imgcodecs imgproc java_bindings_generator ml objdetect photo python2 python3 python_bindings_generator shape stitching superres ts video videoio videostab
Disabled: js world
Disabled by dependency: -
Unavailable: java viz
Applications: tests perf_tests apps
Documentation: NO
Non-free algorithms: NO
GUI:
QT: YES (ver 5.5.1)
QT OpenGL support: YES (Qt5::OpenGL 5.5.1)
GTK+: NO
OpenGL support: YES (/usr/lib/aarch64-linux-gnu/libGLU.so /usr/lib/aarch64-linux-gnu/libGL.so)
VTK support: NO
Media I/O:
ZLib: /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.8)
JPEG: /usr/lib/aarch64-linux-gnu/libjpeg.so (ver )
WEBP: build (ver encoder: 0x020e)
PNG: /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.2.54)
TIFF: /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 / 4.0.6)
JPEG 2000: /usr/lib/aarch64-linux-gnu/libjasper.so (ver 1.900.1)
OpenEXR: build (ver 1.7.1)
Video I/O:
DC1394: NO
FFMPEG: YES
avcodec: YES (ver 56.60.100)
avformat: YES (ver 56.40.101)
avutil: YES (ver 54.31.100)
swscale: YES (ver 3.1.101)
avresample: NO
GStreamer:
base: YES (ver 1.8.3)
video: YES (ver 1.8.3)
app: YES (ver 1.8.3)
riff: YES (ver 1.8.3)
pbutils: YES (ver 1.8.3)
libv4l/libv4l2: 1.10.0 / 1.10.0
v4l/v4l2: linux/videodev2.h
gPhoto2: NO
Parallel framework: pthreads
Trace: YES (built-in)
Other third-party libraries:
Lapack: NO
Eigen: YES (ver 3.2.92)
Custom HAL: YES (carotene (ver 0.0.1))
Protobuf: build (3.5.1)
NVIDIA CUDA: YES (ver 9.0, CUFFT CUBLAS FAST_MATH)
NVIDIA GPU arch: 53
NVIDIA PTX archs:
OpenCL: YES (no extra features)
Include path: /home/nvidia/devel/opencv/opencv/3rdparty/include/opencl/1.2
Link libraries: Dynamic load
Python 2:
Interpreter: /usr/bin/python2.7 (ver 2.7.12)
Libraries: /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.12)
numpy: /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.11.0)
packages path: lib/python2.7/dist-packages
Python 3:
Interpreter: /usr/bin/python3 (ver 3.5.2)
Libraries: /usr/lib/aarch64-linux-gnu/libpython3.5m.so (ver 3.5.2)
numpy: /usr/lib/python3/dist-packages/numpy/core/include (ver 1.11.0)
packages path: lib/python3.5/dist-packages
Python (for build): /usr/bin/python2.7
Java:
ant: NO
JNI: NO
Java wrappers: NO
Java tests: NO
Matlab: NO
Install to: /usr/local
