Below is my basic source to open capture state :
VideoCapture cap (“v4l2src device=/dev/video0 num-buffers=1 ! video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1200 ! appsink”);
if( !cap.isOpened() )
cout<<"Cannot open the camera"<<endl;
return -1;
Opening in BLOCKING MODE
ArgusV4L2_Open failed: No such file or directory
[ WARN:0@0.893] global /home/mt/opencv/modules/videoio/src/cap_gstreamer.cpp (1412) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
[ WARN:0@1.560] global /home/mt/opencv/modules/videoio/src/cap_gstreamer.cpp (2408) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module v4l2src0 reported: Internal data stream error.
[ WARN:0@1.561] global /home/mt/opencv/modules/videoio/src/cap_gstreamer.cpp (904) startPipeline OpenCV | GStreamer warning: unable to start pipeline
[ WARN:0@1.561] global /home/mt/opencv/modules/videoio/src/cap_gstreamer.cpp (1590) setProperty OpenCV | GStreamer warning: no pipeline
[ WARN:0@1.561] global /home/mt/opencv/modules/videoio/src/cap_gstreamer.cpp (1485) getProperty OpenCV | GStreamer warning: GStreamer: no pipeline
CAM_FPS : 0
Error Received While Reading Frame
terminate called after throwing an instance of ‘cv::Exception’
what(): OpenCV(4.6.0-dev) /home/mt/opencv/modules/imgcodecs/src/loadsave.cpp:763: error: (-215:Assertion failed) !_img.empty() in function ‘imwrite’
Aborted (core dumped)
