OpenCV compilation error with CMake in C++
Hello there,
I have OpenCV from source installed but I don’t know why the compilation of my C++ code fails. Can someone who is familiar with C++ explain what is happening please?
My C++ code:
#include
#include <stdio.h>
#include <opencv2/opencv.hpp>
using namespace std;
using namespace cv;
int main() {
	Mat frame;
	cout << "This is the main project." << endl;
	cin.get();
My CMakeLists.txt file:
cmake_minimum_required (VERSION 3.5)
project (main)
set (CMAKE_CXX_STANDARD 11)
set (CMAKE_CXX_STANDARD_REQUIRED TRUE)
set (CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wall -Werror -std=c++11")
set (source_dir "${PROJECT_SOURCE_DIR}/src/")
SET (OpenCV_DIR /home/installation/OpenCV-3.3.1/opencv/include/opencv2)
file (GLOB source_files "${source_dir}/*.cpp")
add_executable (main ${source_files})
Console output when trying to compile with CMake:
CMakeFiles/main.dir/src/Main.cpp.o: In function cv::String::~String()': /usr/include/opencv2/core/cvstd.hpp:648: undefined reference to cv::String::deallocate()’
CMakeFiles/main.dir/src/Main.cpp.o: In function cv::String::operator=(cv::String const&)': /usr/include/opencv2/core/cvstd.hpp:656: undefined reference to cv::String::deallocate()’
CMakeFiles/main.dir/src/Main.cpp.o: In function cv::Mat::~Mat()': /usr/include/opencv2/core/mat.inl.hpp:692: undefined reference to cv::fastFree(void*)’
CMakeFiles/main.dir/src/Main.cpp.o: In function cv::Mat::release()': /usr/include/opencv2/core/mat.inl.hpp:804: undefined reference to cv::Mat::deallocate()’
collect2: error: ld returned 1 exit status
CMakeFiles/main.dir/build.make:94: recipe for target ‘main’ failed
make[2]: *** [main] Error 1
CMakeFiles/Makefile2:67: recipe for target ‘CMakeFiles/main.dir/all’ failed
make[1]: *** [CMakeFiles/main.dir/all] Error 2
Makefile:83: recipe for target ‘all’ failed
make: *** [all] Error 2
Thanks for the answers in advance!
Hi nemestomi2,
Thanks for reaching out!
“undefined reference” usually indicates that the compiler/linker cannot find the shared libraries used by your program.
I notice that you call
add_executable(main ${source_files})
You’ll likely need to also call
target_link_libraries(main <lib1> <lib2>)
To link the necessary libraries. I believe the OpenCV cmake package bundles the libraries into the variable OpenCV_LIBS, in which case you could do
target_link_libraries(main ${OpenCV_LIBS})
Please let me know if this helps or you run into any issues.
Best,
John
thanks for the suggestion! However, it does not work, it outputs the same thing as before.
But I suppose the problem might be also in the set (OpenCV_DIR) command. I followed an online tutorial for installation and setting up my CMakeLists.txt, but the path entered by him in the command does not exist in my installation folder (OpenCV_installation/installation/OpenCV-master/lib/cmake/opencv4). The only lib folder I have does not contain a cmake folder.
So here’s my question: What should the directory I set here contain? .h, .hpp or .so files?
So by now, I have figured out what the problem was, even if I don’t understand why this solved it.
You just have to add following lines to CMakeLists.txt (before you call add_executable or target_link_libraries):
find_package(OpenCV REQUIRED)
include_directories(${OpenCV_INCLUDE_DIRS})
Hope this helps.
