Hello all,
When i try to run the code i made with the HaarCascase method on the terminal screen, i get the following error.
Code end error;
opencv_createsamples -info pozitif.txt -num 50 -vec pozitifResim.vec -w 24 -h 24
bash: opencv_createsamples: command not found
My current OpenCV versions is 4.1.1. What should i do?
Thanks in advance.
