hujhcv
1
I’ve written a simple code to test which CPU and GPU are faster.
This is the code:
#include <opencv2/core.hpp>
#include <opencv2/imgproc.hpp>
#include <opencv2/imgcodecs.hpp>
#include <opencv2/cudaimgproc.hpp>
using namespace std;
using namespace cv;
void canny_cv()
Mat mat=imread("/home//1.jpg",0);
Mat edge;
Canny(mat,edge,50,100);
double t1=getTickCount();
for(int i=0;i<10;i++)
double t2=getTickCount();
cout<<"cv time:"<<(t2-t1)/getTickFrequency()/10<<endl;
void canny_cuda()
Mat mat=imread("/home/1.jpg",0);
Ptr<cv::cuda::CannyEdgeDetector> canny=cv::cuda::createCannyEdgeDetector(50,100);
cv::cuda::GpuMat edge;
cv::cuda::GpuMat src(mat);
canny->detect(src,edge);
cout<<"cuda time:"<<(t2-t1)/getTickFrequency()/10<<endl;
int main(int argc, char *argv[])
canny_cv();
canny_cuda();
return 0;
And I get the results:
cv time: 0.048594s
cuda time: 0.125343s
GPU is slower than CPU?
Are my results normal or am I doing something wrong?
This is related to the OpenCV implementation.
It’s recommended to find openCV engineer for help directly.
Here are some initial suggestion for you:
1. Please build openCV with correct GPU architecture. sm=53 for Nano.
Please ignore this if you are using our default OpenCV package.
2. Please maximize the device performance first.
sudo jetson_clocks
By the way, we also have a library includes canny detector.
You can also give it a try: https://developer.nvidia.com/embedded/visionworks
Hi AastaLLL, Thanks for your reply!
I have rebuilt the openCV with GPU architecture. sm=53. and maximized the device performance.
I have tested visionworks’s Canny too.
But the results confused me!
Canny - CPU OpenCV cost time: 0.06526 sec.
Canny - CUDA OpenCV cost time: 0.09753 sec.
Canny - VisionWorks cost time: 0.20656 sec.
What’s going on here?
Are you measuring latency of a single operation, or throughput of many operations?
VisionWorks is quite interesting. Is it possiblento use it with Python?
Alain
