Does NVIDIA plan on supporting newer versions of openCV (e.g. 3.x) with Tegra support?
Will Tegra GPU eventually be supported in the library (in addition to ARM NEON)?
geoffreywall
To optimize OpenCV 3.x.x for Tegra is still under planning, no clear schedule yet.
If you still want to use OpenCV 3.x, you could try to compile and install OpenCV 3.x by referring the below forum thread:
[url]https://devtalk.nvidia.com/default/topic/917386/jetson-tx1/usb-3-0-port-unstable-on-jetson-tx1-/post/4835793/#4835793[/url]
After built your own version of OpenCV (using the public open-source code), you will still have the full CUDA-optimized “gpu” module but not the CPU optimizations of OpenCV4Tegra.
