Opencv frame as input to deepstream python api pipeline
Are you fixed this issue already?
We write an example for Deepstream with OpenCV input.
Hope this can give you more information.
This example is based on the deepstream-test1 python sample.
1. Download python sample
$ git clone https://github.com/NVIDIA-AI-IOT/deepstream_python_apps.git
$ cd deepstream_python_apps/apps/deepstream-test1
2. Apply changes
diff --git a/apps/deepstream-test1/deepstream_test_1.py b/apps/deepstream-test1/deepstream_test_1.py
index 67be84b..5cfb32b 100644
--- a/apps/deepstream-test1/deepstream_test_1.py
+++ b/apps/deepstream-test1/deepstream_test_1.py
@@ -26,12 +26,26 @@ from common.is_aarch_64 import is_aarch64
 from common.bus_call import bus_call
 import pyds
+import cv2
 PGIE_CLASS_ID_VEHICLE = 0
 PGIE_CLASS_ID_BICYCLE = 1
 PGIE_CLASS_ID_PERSON = 2
 PGIE_CLASS_ID_ROADSIGN = 3
+global cap
+def cb_need_data(appsource, _size, u_data):
+    global cap
+    ret, frame = cap.read()
+    if not ret:
+        appsource.emit("end-of-stream")
+        return
+    frame = cv2.cvtColor(frame, cv2.COLOR_BGR2RGBA)
+    appsource.emit("push-buffer", Gst.Buffer.new_wrapped(frame.tobytes()))
 def osd_sink_pad_buffer_probe(pad,info,u_data):
     frame_number=0
@@ -127,6 +141,14 @@ def main(args):
         sys.stderr.write("usage: %s <media file or uri>\n" % args[0])
         sys.exit(1)
+    global cap
+    cap = cv2.VideoCapture(args[1])
+    width  = int(cap.get(cv2.CAP_PROP_FRAME_WIDTH))
+    height = int(cap.get(cv2.CAP_PROP_FRAME_HEIGHT))
+    if not cap.isOpened():
+        print("Can't open input frame. Exiting ...")
+        exit(-1)
     # Standard GStreamer initialization
     GObject.threads_init()
     Gst.init(None)
@@ -141,22 +163,19 @@ def main(args):
     # Source element for reading from the file
     print("Creating Source \n ")
-    source = Gst.ElementFactory.make("filesrc", "file-source")
-    if not source:
+    appsource = Gst.ElementFactory.make("appsrc", "opencv-source")
+    if not appsource:
         sys.stderr.write(" Unable to create Source \n")
-    # Since the data format in the input file is elementary h264 stream,
-    # we need a h264parser
-    print("Creating H264Parser \n")
-    h264parser = Gst.ElementFactory.make("h264parse", "h264-parser")
-    if not h264parser:
-        sys.stderr.write(" Unable to create h264 parser \n")
+    # Use convertor to convert RGBA to NV12
+    nvvideoconvert = Gst.ElementFactory.make("nvvideoconvert","nv-videoconv")
+    if not nvvideoconvert:
+        sys.stderr.write(" Unable to create nvvideoconvert \n")
-    # Use nvdec_h264 for hardware accelerated decode on GPU
-    print("Creating Decoder \n")
-    decoder = Gst.ElementFactory.make("nvv4l2decoder", "nvv4l2-decoder")
-    if not decoder:
-        sys.stderr.write(" Unable to create Nvv4l2 Decoder \n")
+    # cap filter
+    caps_filter = Gst.ElementFactory.make("capsfilter","capsfilter")
+    if not caps_filter:
+        sys.stderr.write(" Unable to create caps_filter \n")
     # Create nvstreammux instance to form batches from one or more sources.
     streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
@@ -190,17 +209,21 @@ def main(args):
         sys.stderr.write(" Unable to create egl sink \n")
     print("Playing file %s " %args[1])
-    source.set_property('location', args[1])
-    streammux.set_property('width', 1920)
-    streammux.set_property('height', 1080)
+    caps1 = Gst.Caps.from_string("video/x-raw,format=RGBA,width=%d,height=%d,framerate=30/1"%(width, height))
+    caps2 = Gst.Caps.from_string("video/x-raw(memory:NVMM),format=NV12,width=%d,height=%d,framerate=30/1"%(width, height))
+    appsource.set_property('caps', caps1)
+    caps_filter.set_property('caps',caps2)
+    streammux.set_property('width', width)
+    streammux.set_property('height', height)
     streammux.set_property('batch-size', 1)
     streammux.set_property('batched-push-timeout', 4000000)
     pgie.set_property('config-file-path', "dstest1_pgie_config.txt")
     print("Adding elements to Pipeline \n")
-    pipeline.add(source)
-    pipeline.add(h264parser)
-    pipeline.add(decoder)
+    pipeline.add(appsource)
+    pipeline.add(nvvideoconvert)
+    pipeline.add(caps_filter)
     pipeline.add(streammux)
     pipeline.add(pgie)
     pipeline.add(nvvidconv)
@@ -213,13 +236,13 @@ def main(args):
     # file-source -> h264-parser -> nvh264-decoder ->
     # nvinfer -> nvvidconv -> nvosd -> video-renderer
     print("Linking elements in the Pipeline \n")
-    source.link(h264parser)
-    h264parser.link(decoder)
+    appsource.link(nvvideoconvert)
+    nvvideoconvert.link(caps_filter)
     sinkpad = streammux.get_request_pad("sink_0")
     if not sinkpad:
         sys.stderr.write(" Unable to get the sink pad of streammux \n")
-    srcpad = decoder.get_static_pad("src")
+    srcpad = caps_filter.get_static_pad("src")
     if not srcpad:
         sys.stderr.write(" Unable to get source pad of decoder \n")
     srcpad.link(sinkpad)
@@ -238,6 +261,7 @@ def main(args):
     bus.add_signal_watch()
     bus.connect ("message", bus_call, loop)
+    appsource.connect("need-data", cb_need_data, "need-data")
     # Lets add probe to get informed of the meta data generated, we add probe to
     # the sink pad of the osd element, since by that time, the buffer would have
     # had got all the metadata.
3. Test
$ export DISPLAY=:0
$ python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.mp4
