opencv_gpu compilation problem
I use cmake to generate a opencv solution with CUDA enabled. When I try to compile the project, the opencv_gpu project gives following error:
error C3861: ‘nppiCannyGetBufferSize’: identifier not found
error C3861: ‘nppiCanny_32f8u_C1R’: identifier not found
error C2664: ‘nppiSum_8u_C1R’ : cannot convert parameter 4 from ‘Npp32s *’ to ‘Npp8u *’
error C2664: ‘nppiSum_8u_C4R’ : cannot convert parameter 4 from ‘Npp32s *’ to ‘Npp8u *’
I am using NPP 3.2.16. Other projects seem compile fine. Thank you.
the problem still exist. Any suggestions?
