Hey,
Im trying to compile opencv2.3 with CUDA, and constantly get the following error:
Error 54 error LNK2001: unresolved external symbol “void __cdecl cv::gpu::error(char const *,char const *,int,char const *)” (?error@gpu@cv@@YAXPBD0H0@Z) cuda_compile_generated_stereobp.cu.obj opencv_gpu
And about 20 similar errors.
How can i solve it?
are you trying to use OpenCV in a .cu file? Or more specifically, are you #include’ing OpenCV headers into a .cu file?
Gintoki
3
I met the same problem.
I guess you used the Cmake to build the opencv2.3 and cuda 4.0. Peahaps you can use the compiled library in the website:
Though I failed with this method, you can have a try.
If you solve the problems, please share~ Good luck.
