OpenCV GPU invalid configuration argument in function 'call'
Opencv resize has two ways for specifying resize factors.
First one is the cv::Size dsize, second one is the pair of factors fx and fy.
I’d suggest to use cv::Size only. Here is a sample of code doing capture with CSI onboard camera using gstreamer (you need an opencv build with gstreamer support).
#include <iostream>
#include <time.h>
#include <opencv2/opencv.hpp>
#include <opencv2/video.hpp>
#include <opencv2/highgui.hpp>
#include <opencv2/cudawarping.hpp>
static inline unsigned long int GetTimeNs()
	struct timespec curTime;
	timespec_get(&curTime, TIME_UTC);
	return  curTime.tv_sec * 1e9 + curTime.tv_nsec;
//#define USE_OPENGL 1
int main()
	//printf("%s\n", cv::getBuildInformation().c_str());
	//setenv("GST_DEBUG", "*:3", 0);
	const char* gst = "nvcamerasrc  ! video/x-raw(memory:NVMM), format=I420, width=640, height=480, framerate=30/1 ! "
					  "nvvidconv    ! video/x-raw, format=BGRx, width=640, height=480, framerate=30/1 ! "
					  "videoconvert ! video/x-raw, format=BGR,  width=640, height=480, framerate=30/1 ! "
					  "appsink";
	cv::VideoCapture cap(gst);
   	if(!cap.isOpened()) {
		std::cout<<"Failed to open camera."<<std::endl;
		return (-1);
	cv::Mat frame_in, frame_out;
	cv::cuda::GpuMat g_frame_in, g_frame_out;
   	if (!cap.read(frame_in)) {
		std::cout<<"Capture read error"<<std::endl;
		return (-2);
#ifndef USE_OPENGL
	cv::namedWindow("MyCamera", cv::WINDOW_AUTOSIZE);
   	cv::namedWindow("MyResizedCamera", cv::WINDOW_AUTOSIZE);
#else /* USE_OPENGL */
	cv::namedWindow("MyCamera", cv::WINDOW_AUTOSIZE | cv::WINDOW_OPENGL);
	cv::namedWindow("MyResizedCamera", cv::WINDOW_AUTOSIZE | cv::WINDOW_OPENGL);
#endif /* USE_OPENGL */
	unsigned long int endClk = GetTimeNs();
	unsigned long int startClk, imshowClk, waitKeyClk;
	unsigned int frameCount = 0;
	unsigned int lastPos = cap.get(cv::CAP_PROP_POS_MSEC);
	unsigned int newPos, interval;
	unsigned int prevTraceLen = 0;
	while(1)
			break;
		else  {
			startClk = GetTimeNs();
			clock_t captureLen = startClk - endClk;
 			newPos = cap.get(cv::CAP_PROP_POS_MSEC);
			interval = newPos - lastPos;
			lastPos = newPos;
			// Start Host2Device copy + CUDA Process
			g_frame_in.upload(frame_in);
			cv::Size newSize( g_frame_in.size().width / 2 , g_frame_in.size().height / 2 );
			cv::cuda::resize(g_frame_in, g_frame_out, newSize, 0, 0, cv::INTER_AREA);
			g_frame_out.download(frame_out);
			// End CUDA Process + Device2Host Process
			imshowClk = GetTimeNs();
			clock_t processLen = imshowClk - startClk;
#ifndef USE_OPENGL
			cv::imshow("MyCamera", frame_in);
			cv::imshow("MyResizedCamera", frame_out);
			cv::imshow("MyCamera", g_frame_in);
			cv::imshow("MyResizedCamera", g_frame_out);
			waitKeyClk = GetTimeNs();
			clock_t imshowLen = waitKeyClk - imshowClk;
			if (cv::waitKey(1) == 27) // If ESC key has been pressed then exit
				break;
			clock_t waitKeyLen = endClk - waitKeyClk;
			clock_t loopLen = endClk - startClk;
			printf("#%04d: pos_interval=%d, cap=%f, proc=%f, show=%f, waitKey=%f, loop=%f, prevTrace=%f\n",
				frameCount, interval, captureLen/1.e6, processLen/1.e6, imshowLen/1.e6, waitKeyLen/1.e6,
				loopLen/1.e6, prevTraceLen/1e6);
			frameCount++;
			prevTraceLen = GetTimeNs() - endClk;
			endClk += prevTraceLen;
	cap.release();
	return 0;
