Hello, I have a Logitech c310 webcam connected to a Jetson TK1 with OpenCV 2.4.10.1 installed (built from source). This camera can capture 1280x960 video at 30fps. v4l2-ctl --list-formats-ext verifies this:
ubuntu@tegra-ubuntu:~$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Name : YUV 4:2:2 (YUYV)
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.040s (25.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.200s (5.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Index : 1
Pixel Format: 'MJPG' (compressed)
This output shows that the camera can capture in both YUYV and MJPG.
In Cheese I can capture a perfect 1280x960 video from the camera. After doing that,
v4l2-ctl -V
shows that the camera is set to MJPG format:
ubuntu@tegra-ubuntu:~$ v4l2-ctl -V
Format Video Capture:
Width/Height : 1280/960
Pixel Format : 'MJPG'
Field : None
Bytes per Line: 0
Size Image : 816000
Colorspace : SRGB
But when I try to capture a frame in OpenCV from Python, the output changes to:
Width/Height : 640/480
Pixel Format : 'YUYV'
Field : None
Bytes per Line: 1280
Size Image : 614400
Colorspace : SRGB
Now the format is YUYV, and OpenCV will only capture 640x480 images from the camera. Trying to set the width and height properties of the capture to 1280x960 works, but then the program hangs next time a frame is captured.
This seems to me like a problem with OpenCV, not the webcam, since Cheese works perfectly.
Any help would be appreciated!
