I have a hikvision web camera,I use the tx2 receive the video from that camera,and I use this line “cap.open(“rtspsrc location="rtsp://user:password@IP/h.264/ch1/main/av_stream"latency=10 ! rtph264depay ! h264parse ! omxh264dec ! videoconvert ! appsink sync=false”);”,when it runs,it shows “videoio error: V4L device rtspsrc” ,but it also works in the most of time ,but some time it doesn’t work and the window change to black and stop work,so what’s the problem is it? Thanks for your advice
Related topics
| opencv problem with capturing rtsp stream using gstreamer on tx2 | 15 | 19280 | December 16, 2020 | |
| Connect camera ip (Hikvision) to jetson tx2 without internet | 4 | 1655 | August 24, 2020 | |
| IP camera streaming on Jetson TX2 | 14 | 7108 | March 12, 2018 | |
| Can't get GStreamer RTSP working on TX2 | 18 | 4635 | April 26, 2018 | |
| Read IP Camera frames through rtsp fail | 1 | 765 | August 26, 2019 | |
| Error while streaming ethernet camera with RTSP protocol | 7 | 16446 | May 24, 2022 | |
| gst-launch-1.0 using rtspsrc can't play rtsp stream, but using playbin can play rtsp stream ? | 3 | 11232 | December 19, 2018 | |
| TX2 Jetpack4.2.2 Deepstream4.0 can't show RTST video | 6 | 740 | November 28, 2019 | |
| Problem with receiving RTSP stream | 7 | 433 | June 18, 2025 | |
| decode the rtsp stream from a IP camera | 25 | 10156 | November 11, 2019 |
