I used Jetpack to install environments on Linux18.04 host and Xavier. It appears that Openvc3.3.1 is installed, but the opencv2/tracking.hpp header is missing. I see the same problem on both the host and the Xavier. I assume Jetpack installed Opencv4Tegra and I hope to use that, I don’t want to build from source because I want the optimizations.
Is the entire tracking feature absent? Is this because of the annoying SIFT and SURF thing?
Is there a workaround that doesn’t throw away the optimizations?
Most optimization for Jetson is upstreaming.
It’s recommended to build it from source to get the latest feature:
https://github.com/AastaNV/JEP/blob/master/script/install_opencv3.4.0.sh
We include OpenCV package just for providing users some the basic vision operation.
You will need to build it if some required feature is not supported.
These trackers may only be available from opencv_contrib.
You may clone the branch for your opencv release, and there will be a modules directory in this cloned source tree. You would pass this modules directory’s path as CMake option OPENCV_EXTRA_MODULES_PATH and these should be built as other extra modules.
Additional note: in opencv4, cuda libs will only be available from opencv_contrib, so it may be useful to get familiar with this.
Thanks. I’ve worked though this and have found a few surprises. AastaLLL, your script was helpful but some references are missing when run on 18.04. I’ve got things working, but a few run time hangups occur in special cases with ROS. When I get it all sorted out I’ll post notes.
