OpenCV Video Capture with GStreamer doesn't work on ROS-melodic
Hello. I am a beginner of ROS. I tried to stream video using OpenCV Video Capture and GStreamer on Ubuntu 18.04 LTS(NVIDIA Jetson TX2) and ROS-melodic. I wanted a node to publish image which is from cv2.VideoCapture with GStreamer pipeline, to a subscribing node and it show the image using cv2.imshow().
However, when I roslaunch the package, it doesn’t show the image on a window, just keep run with warning message:
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (933) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
I added ‘print()’ to check what the problem is and commented publishing part to check the captured image, but the string didn’t be printed not at all.
I attached the code of main node.
#!/usr/bin/env python
import rospy
from sensor_msgs.msg import Image
import sys
import cv2
import gi
import numpy as np
from cv_bridge import CvBridge
gi.require_version('Gst', '1.0')
from gi.repository import Gst
class Camera:
    def __init__(self):
        self.pub = rospy.Publisher("/camera_test/images", Image, queue_size=1)
        self.cvb = CvBridge()
    def read_cam(self):
        # cap = cv2.VideoCapture(0)
        cap = cv2.VideoCapture("nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080,format=(string)NV12, framerate=(fraction)30/1 ! nvvidconv ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink")
        if cap.isOpened():
            print("cap is opened but") # NOT PRINTED
            cv2.namedWindow("demo", cv2.WINDOW_AUTOSIZE)
            while not rospy.core.is_shutdown():
                ret_val, img = cap.read()
                print("img type is : ", type(img)) # NOT PRINTED
                cv2.imshow('demo', img) # NOT SHOW
                # send image to pub node using cvbridge
                # self.pub.publish(self.cvb.cv2_to_imgmsg(img, 'bgr8'))
                # cv2.imshow('demo',img)
                # if cv2.waitKey(1) == ord('q'):
                #     break
        else:
            print("Cap failed")
if __name__=="__main__":
    cam = Camera()
    rospy.init_node('camera')
    try:
        cam.read_cam()
        rospy.spin()
        outcome = 'Test Completed'
    except rospy.ROSInterruptException:
        print("Exception")
        pass
    rospy.core.signal_shutdown(outcome)
Help me, thank you:D
Please run gst-launch-1.0 command to confirm the source is valid.
$ gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080,format=(string)NV12, framerate=(fraction)30/1' ! nvoverlaysink
Once you confirm the source is valid, you may also try this simple code:
import sys
import cv2
def read_cam():
    cap = cv2.VideoCapture("nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080,format=(string)NV12, framerate=(fraction)30/1 ! nvvidconv ! video/x-raw, format=(string)BGRx ! videoconvert !  appsink")
    if cap.isOpened():
        while True:
            ret_val, img = cap.read();
            cv2.waitKey(10)
    else:
     print "camera open failed"
    cv2.destroyAllWindows()
if __name__ == '__main__':
    read_cam()
I have the same issue.
I have the raspberry pi camera v2.1 and jetson nano dev kit
if I run
I get the video stream on the screen, but when I try to run the jetcam I get the error:
#!/usr/bin/python
import sys
import jetson.inference
import jetson.utils
import cv2
sys.path.append('/usr/local/lib/python3.6/dist-packages/jetcam-0.0.0-py3.6.egg')
from jetcam.csi_camera import CSICamera
# create the camera and display
camera = CSICamera(width=224, height=224, capture_width=1080, capture_height=720, capture_fps=30)
display = jetson.utils.glDisplay()
while display.IsOpen():
	img = camera.read()
	display.RenderOnce(img, 1080, 720)
it outputs:
jetson_2@jetson:~$ ./camera.py
jetson.inference.__init__.py
jetson.inference -- initializing Python 2.7 bindings...
jetson.inference -- registering module types...
jetson.inference -- done registering module types
jetson.inference -- done Python 2.7 binding initialization
jetson.utils.__init__.py
jetson.utils -- initializing Python 2.7 bindings...
jetson.utils -- registering module functions...
jetson.utils -- done registering module functions
jetson.utils -- registering module types...
jetson.utils -- done registering module types
jetson.utils -- done Python 2.7 binding initialization
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 4
   Output Stream W = 1280 H = 720
   seconds to Run    = 0
   Frame Rate = 120.000005
GST_ARGUS: PowerService: requested_clock_Hz=5103000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
jetson.utils -- PyDisplay_New()
jetson.utils -- PyDisplay_Init()
[OpenGL] glDisplay -- X screen 0 resolution:  1920x1080
[OpenGL] glDisplay -- display device initialized
  File "./camera.py", line 38, in <module>
Exception: jetson.utils -- glDisplay.RenderOnce() failed to get image pointer from PyCapsule container
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
jetson.utils -- PyDisplay_Dealloc()
GST_ARGUS:
PowerServiceHwVic::cleanupResources
One more thing, I’m also trying to run this camera, but nvarguscamerasrc return “no camera available”:
https://www.amazon.com/Camera-Module-Raspberry-Supports-Compatible/dp/B073183KYK/ref=sr_1_5?keywords=raspberry+pi+infrared+camera+ov5647&qid=1584050083&sr=8-5
is it incopatible with jetson nano?
Hi ricardobittencourt,
Please open a new topic in Jetson Nano forum. Thanks
Thank you so much this script finally worked for me . But how can i open another usb camera which is located on ‘/dev/video1’ using this code . Specifically how to i pass this argument
Hi aditya.s.bodkhe,
Please help to open a new topic if it’s still an issue to support. Thanks
Hii , I’ve got it working correctly .Thanks
