and to stream both cameras stitched together as bash script:
gst-launch-1.0 nvcompositor name=comp \
sink_0::xpos=0 sink_0::ypos=0 sink_0::width=1280 sink_0::height=720 \
sink_1::xpos=0 sink_1::ypos=720 sink_1::width=1280 sink_1::height=720 ! \
nvvidconv ! \
nvv4l2h264enc bitrate=16000000 insert-sps-pps=true ! \
rtph264pay mtu=1400 ! \
udpsink host=192.168.0.106 port=5000 \
nvarguscamerasrc sensor-id=0 sensor-mode=3 ! \
'video/x-raw(memory:NVMM),
width=1280,
height=720,
format=NV12,
framerate=60/1' ! \
nvvidconv flip-method=0 ! \
comp.sink_0 \
nvarguscamerasrc sensor-id=1 sensor-mode=3 ! \
width=1280,
height=720,
format=NV12,
framerate=60/1' ! \
comp.sink_1
receive with
application/x-rtp,encoding-name=H264,payload=96 ! \
rtph264depay ! \
h264parse ! \
queue ! \
avdec_h264 ! \
autovideosink sync=false async=false -e
hello @thompson.reed thanks for the base example for streaming. What i am trying to do is stream processed videos from an rtsp link.
I can display my processed images in numpy array format but I could not stream it over the network. When I try your example like:
import cv2
import threading
import numpy as np
# gstreamer_pipeline returns a GStreamer pipeline for capturing from the CSI camera
# Flip the image by setting the flip_method (most common values: 0 and 2)
# display_width and display_height determine the size of each camera pane in the window on the screen
cam = None
class CSI_Camera:
def __init__ (self) :
# Initialize instance variables
# OpenCV video capture element
self.video_capture = None
# The last captured image from the camera
self.frame = None
self.grabbed = False
# The thread where the video capture runs
self.read_thread = None
self.read_lock = threading.Lock()
self.running = False
def open(self, gstreamer_pipeline_string):
try:
self.video_capture = cv2.VideoCapture(
gstreamer_pipeline_string, cv2.CAP_GSTREAMER
except RuntimeError:
print("Unable to open camera")
print("Pipeline: " + gstreamer_pipeline_string)
return
# Grab the first frame to start the video capturing
self.grabbed, self.frame = self.video_capture.read()
def start(self):
if self.running:
print('Video capturing is already running')
return None
# create a thread to read the camera image
if self.video_capture != None:
self.running=True
self.read_thread = threading.Thread(target=self.updateCamera)
self.read_thread.start()
return self
def stop(self):
self.running=False
self.read_thread.join()
def updateCamera(self):
# This is the thread to read images from the camera
while self.running:
try:
grabbed, frame = self.video_capture.read()
with self.read_lock:
self.grabbed=grabbed
self.frame=frame
print("Could not read image from camera")
# FIX ME - stop and cleanup thread
# Something bad happened
def read(self):
frame = self.frame.copy()
grabbed=self.grabbed
return grabbed, frame
def release(self):
self.video_capture.release()
# Now kill the thread
if self.read_thread != None:
# Currently there are setting frame rate on CSI Camera on Nano through gstreamer
# Here we directly select sensor_mode 3 (1280x720, 59.9999 fps)
def gstreamer_pipeline():
return (
"nvarguscamerasrc sensor-id=1 sensor-mode=3 ! "
"video/x-raw(memory:NVMM), "
" width=1280, "
" height=720, "
" format=NV12, "
" framerate=60/1 ! "
"nvvidconv flip-method=0 ! "
"videoconvert ! "
"video/x-raw, format=BGR ! "
" appsink"
def gstreamer_pipeline_out():
return (
"appsrc ! "
"queue ! "
"videoconvert ! "
"video/x-raw, format=BGRx ! "
"nvvidconv ! "
"omxh264enc ! "
"video/x-h264, stream-format=byte-stream ! "
"h264parse ! "
"rtph264pay pt=96 config-interval=1 ! "
"udpsink host=192.168.0.110 port=5000"
def start_cameras():
cap_vid = cv2.VideoCapture("/home/nvidia/Downloads/s1.mp4")
out = cv2.VideoWriter(gstreamer_pipeline_out(), 0, 60, (1280,720))
while not out.isOpened():
print('VideoWriter not opened')
SystemExit(0)
while True :
ret, frame_vid = cap_vid.read()
img = cv2.blur(frame_vid,(3,3))
#img = cv2.medianBlur(img,9)
out.write(img)
# cam.stop()
# cam.release()
if __name__ == "__main__":
start_cameras()
But at the end I cannot get the stream.
Best Regards
