Opencv with cuda in Multi-threads doesn't work
Here is my test code:
void Process()
GpuMat GpuRGBSrc;
Mat CpuRGBSrc;
Src.copyTo(CpuRGBSrc);
GpuRGBSrc.upload(CpuRGBSrc);
int MatchMethod = TM_SQDIFF;
PtrTemplateMatcher = createTemplateMatching(GpuRGBSrc.type(), MatchMethod);
GpuMat MatchResult;
double MinVal, MaxVal, MatchVal;
Point MinLocal, MaxLocal, MatchLocal;
GpuMat TG;
TG.upload(T1);
TickMeter t;
TemplateMatcher->match(GpuRGBSrc, TG, MatchResult);
void* Thread1(void* arg)
while (1)
TickMeter t;
t.start();
Process();
t.stop();
cout << “Thread1 Time:”<<t.getAvgTimeMilli() << endl;
return 0;
void* Thread2(void* arg)
while (1)
TickMeter t;
t.start();
Process();
t.stop();
cout << “Thread2 Time:”<< t.getAvgTimeMilli() << endl;
return 0;
void* Thread3(void* arg)
while (1)
TickMeter t;
t.start();
Process();
t.stop();
cout << “Thread3 Time:” <<t.getAvgTimeMilli() << endl;
return 0;
void* Thread4(void* arg)
while (1)
TickMeter t;
t.start();
Process();
t.stop();
cout << “Thread4 Time:”<<t.getAvgTimeMilli() << endl;
return 0;
int main()
pthread_t ListenHandle1,ListenHandle2,ListenHandle3,ListenHandle4,ListenHandle5,ListenHandle6;
T1 = imread(“/media/hjy/SSD/CigPrint/MB1.bmp”);
T2 = imread(“/media/hjy/SSD/CigPrint/MB2.bmp”);
Src = imread(“/media/hjy/SSD/CigPrint/src.bmp”);
pthread_create(&ListenHandle1,NULL,Thread1,NULL);
// pthread_create(&ListenHandle2,NULL,Thread2,NULL);
// pthread_create(&ListenHandle3,NULL,Thread3,NULL);
// pthread_create(&ListenHandle4,NULL,Thread4,NULL);
while(1);
if only create one thread ,Thread1 time:23ms, GPU usage is 20%-40%.
if create two threads,Thread1 and Thread2 time both are 47ms,GPU usage is 20%-40%,which isn’t increased.
the more thread is created,the process time is increase,but GPU usage isn’t increased.I have tested that the thread is parallel in CPU,but the more thread is created,the process time of one thread is increase,it seems that it is not concurrency in GPU.
The same code i have tested in my Windoes computer,but result is different.The more thread is created,the process time is same,and GPU usage is increased.So why Opencv with cuda in Multi-threads doesn’t work on jetson?Is there any tips to solve the problem.
Could you run the app with a profiler to check if the GPU task is executed in a different CUDA stream?
How to use profiler?Is it a application on jetson?
You can use Nsight System:
CLI can work on both desktop (remote profile) and Jetson.
But the UI version only support desktop with remote profiling.
