opencv4tegra for host downloading error
Hi all!
i am trying to download packages for host and jetson tx2 and i am getting downloading error for opencv4tegra for host.
i don’t know why jetpack should take care of downloading package.
Hi msee17001,
Please refer to the System Requirements section for supported hardware configurations:
http://docs.nvidia.com/jetpack-l4t/3.1/content/developertools/mobile/jetpack/l4t/3.1/jetpack_l4t_main.htm#System_Requirements
Following install guide to installing jetpack:
http://docs.nvidia.com/jetpack-l4t/3.1/index.html#developertools/mobile/jetpack/l4t/3.1/jetpack_l4t_install.htm
I got the same issue. I had OpenCV4Tegra running on Ubuntu 16.04 and had to reinstall it and now I get the downloading error in the JetPack 3.1.
Hi all,
I have the same downloading error since Saturday 11 Nov.
Hi all, thanks for reporting, we detected this was a server caching issue and after clearing the cache, the issue appears resolved.
Please let us know if you still have trouble downloading the package using JetPack.
I am experiencing this problem since yesterday evening (Australia UTC+11 hours).
No sure if this is related, on Jetson TX2 side, a “sudo yum update” gives this warning:
W: Invalid ‘Date’ entry in Release file /var/lib/apt/lists/_var_libopencv4tegra-repo_Release
Jetsons don’t run Fedora/RedHat/CentOS…at least not without a custom setup. Any Fedora repo will probably be unofficial. Is this an alternative rootfs?
The host is Ubuntu 16.04 LTS
I mention that because yum is not an Ubuntu tool. It would be apt or apt-get.
