I am trying to create a CUDA program to draw pixels in a plane. The coordinates of my pixels are computed with a CUDA kernel sharing datas with a OpenGL buffer.
I modified a code from “CUDA by Example” using a structure where all fonctions are listed. The Draw fonction is composed of:
static void Draw( void ) {
GPUAnimBitmap* bitmap = *(get_bitmap_ptr());
glClear( GL_COLOR_BUFFER_BIT );
glDrawPixels( bitmap->width, bitmap->height, GL_RGBA,GL_UNSIGNED_BYTE, NULL);
glutSwapBuffers();
The first strange fact is that glDrawPixels is expected to take my data pointer in last argument but I give it a NULL and it works.
My problem is that it seems OpenGL adds a third dimension to my coordinates. I can see a sort of sphere in stead of 2D circle.
I see something approximatively like that
I guess this is a OpenGL configuration that I miss or don’t do.
Thank your for your help.
