I need to display OpenGL scene (in fullscreen) as fast a possible.
On 4K monitor, displaying (rendering onto Default Framebuffer) takes 4.8 ms.
However, rendering onto off-screen Framebuffer takes only 1.1 ms.
I decided to ask here and not on OpenGL forum because on my PC (with GeForce) the timing is the same.
Which is something I’d expect, since Default Framebuffer is still a Framebuffer (only out-of-reach).
So it seems like a problem specific to Jetson TK1.
Is the slowdown of the Default Framebuffer is expected on Jetson TK1?
Or is there “a switch” to make it faster? Where can I read about it?
Couple of thoughts:
- There is a switch (Env variable
__GL_SYNC_TO_VBLANK
) to enable VSync, so maybe there is a similar feature that is responsible for the slowdown. - X11 could cause the slowdown, but it’s unlikely because it does not affect the speed on the PC.
Here is the code:
#include <stdio.h>
#include <assert.h>
#define GL_GLEXT_PROTOTYPES
#include <GL/freeglut.h>
#include <Stopwatch.hpp>
//#define USE_FRAMEBUFFER
void Init() {
int width = glutGet(GLUT_SCREEN_WIDTH), height = glutGet(GLUT_SCREEN_HEIGHT);
glViewport(0, 0, width, height);
#ifdef USE_FRAMEBUFFER
GLuint render_buffer;
glGenRenderbuffers(1, &render_buffer);
glBindRenderbuffer(GL_RENDERBUFFER, render_buffer);
glRenderbufferStorage(GL_RENDERBUFFER, GL_RGBA8, width, height);
assert(glGetError()==GL_NO_ERROR);
GLuint frame_buffer;
glGenFramebuffers(1, &frame_buffer);
glBindFramebuffer(GL_FRAMEBUFFER, frame_buffer);
glFramebufferRenderbuffer(GL_FRAMEBUFFER, GL_COLOR_ATTACHMENT0, GL_RENDERBUFFER, render_buffer);
assert(glCheckFramebufferStatus(GL_FRAMEBUFFER)==GL_FRAMEBUFFER_COMPLETE);
#endif
static GLfloat vertex[] = {0, 0, -1, -1, 1, -1};
glVertexPointer(2, GL_FLOAT, 0, vertex);
static GLfloat color[] = {0, 0, 1, 0, 1, 0, 1, 0, 0};
glColorPointer(3, GL_FLOAT, 0, color);
glEnableClientState(GL_VERTEX_ARRAY);
glEnableClientState(GL_COLOR_ARRAY);
glClearColor(.2f, .2f, .2f, 1); // Background color.
void Display() {
glClear(GL_COLOR_BUFFER_BIT);
glDrawArrays(GL_TRIANGLES, 0, 3);
glFinish();
int main(int argc, char *argv[]) {
glutInit(&argc, argv);
glutInitWindowSize(640, 480); // Does not matter, since we render to off-screen buffer.
glutCreateWindow("Demo");
#else
glutEnterGameMode();
#endif
Init();
const int count = 2000;
Stopwatch sw;
for (int i = 0; i<count; ++i) Display();
printf("Average display time is %.2lf ms.\n", sw.Time()/count*1000);
/* On 4K monitor, with (without) `USE_FRAMEBUFFER` defined: 1.1 ms (4.8 ms).
If `glFlush()` is used instead of `glFinish()`, then the time is 0.4 ms (2.0 ms). */
return 0;
Compile with command g++ main.cpp -lglut -lX11 -lGL -lGLU -ldrm
