OpenGL doesnt work with 410.57 / Solaris 11.4
I’m having after upgrading to the 410.57 drivers, however, I’m not sure if this is the complete problem as downgrading doesn’t seem to fix it either. Basically X starts and shows GLX and NV-GLX but nothing, including the window manager, can use GL graphics.
I get this when running glxinfo:
% DISPLAY=:0 glxinfo
name of display: :0
X Error of failed request:  BadValue (integer parameter out of range for operation)
  Major opcode of failed request:  155 (GLX)
  Minor opcode of failed request:  24 (X_GLXCreateNewContext)
  Value in failed request:  0x0
  Serial number of failed request:  73
  Current serial number in output stream:  74
I’ve made sure the nvidia drivers have loaded by setting the property options/vendor to nvidia for the ogl-select service and:
% ls -l /system/volatile/opengl/lib/amd64/libGL.so.1
lrwxrwxrwx 1 root root 36 Oct 11 11:08 /system/volatile/opengl/lib/amd64/libGL.so.1 → /usr/X11/lib/NVIDIA/amd64/libGL.so.1
verifies it is linking to the nvidia GL drivers. Anyone have any ideas? Here is my Xorg log:
[129971.427]
X.Org X Server 1.19.5
Release Date: 2017-10-12
[129971.428] X Protocol Version 11, Revision 0
[129971.428] Build Operating System: SunOS 5.11 i86pc
[129971.428] Current Operating System: SunOS galaxy3 5.11 11.4.1.4.0 i86pc
[129971.428] Solaris ABI: 64-bit
[129971.428] Current version of pixman: 0.34.0
[129971.428]    Before reporting problems, check https://support.oracle.com/
        to make sure that you have the latest version.
[129971.428] Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[129971.429] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Oct 11 11:44:54 2018
[129971.429] (==) Using config file: "/etc/X11/xorg.conf"
[129971.429] (==) Using config directory: "/etc/X11/xorg.conf.d"
[129971.429] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[129971.430] (==) ServerLayout "Layout0"
[129971.430] (**) |-->Screen "Screen0" (0)
[129971.430] (**) |   |-->Monitor "<default monitor>"
[129971.430] (**) |   |-->Device "Device0"
[129971.430] (==) No monitor specified for screen "Screen0".
        Using a default monitor configuration.
[129971.430] (**) |-->Input Device "Keyboard0"
[129971.430] (**) |-->Input Device "Mouse0"
[129971.430] (**) Option "Xinerama" "0"
[129971.431] (==) Automatically adding devices
[129971.431] (==) Automatically enabling devices
[129971.431] (==) Not automatically adding GPU devices
[129971.431] (==) Max clients allowed: 256, resource mask: 0x1fffff
[129971.431] (**) FontPath set to:
        catalogue:/etc/X11/fontpath.d,
[129971.431] (==) ModulePath set to "/usr/lib/xorg/modules,/usr/X11/lib/modules/"
[129971.431] (**) Extension "Composite" is enabled
[129971.431] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[129971.431] (WW) Disabling Keyboard0
[129971.431] (WW) Disabling Mouse0
[129971.431] (II) Loader magic: 803330
[129971.431] (II) Module ABI versions:
[129971.431]    X.Org ANSI C Emulation: 0.4
[129971.431]    X.Org Video Driver: 23.0
[129971.432]    X.Org XInput driver : 24.1
[129971.432]    X.Org Server Extension : 10.0
[129971.440] (--) PCI: (0:19:0:0) 10de:0ffd:10de:0967 rev 161, Mem @ 0xc6000000/16777216, 0x383fe0000000/268435456, 0x383ff0000000/33554432, I/O @ 0x00005000/128
[129971.440] (--) PCI:*(0:61:0:0) 102b:0522:108e:4853 rev 5, Mem @ 0xc4000000/16777216, 0xc5810000/16384, 0xc5000000/8388608
[129971.440] (--) PCI: (0:176:0:0) 10de:0ffd:10de:0967 rev 161, Mem @ 0xfa000000/16777216, 0x387dd0000000/268435456, 0x387de0000000/33554432, I/O @ 0x0000f000/128
[129971.441] (II) LoadModule: "glx"
[129971.442] (II) Loading /usr/X11/lib/modules/extensions/NVIDIA/amd64/libglx.so
[129971.464] (II) Module glx: vendor="NVIDIA Corporation"
[129971.465]    compiled for 4.0.2, module version = 1.0.0
[129971.465]    Module class: X.Org Server Extension
[129971.465] (II) NVIDIA GLX Module  410.57  Tue Sep 18 23:22:26 CDT 2018
[129971.465] (II) LoadModule: "nvidia"
[129971.466] (II) Loading /usr/X11/lib/modules/drivers/amd64/nvidia_drv.so
[129971.468] (II) Module nvidia: vendor="NVIDIA Corporation"
[129971.468]    compiled for 4.0.2, module version = 1.0.0
[129971.468]    Module class: X.Org Video Driver
[129971.468] (II) NVIDIA dlloader X Driver  410.57  Tue Sep 18 23:23:44 CDT 2018
[129971.468] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[129971.468] (++) using VT number 7
[129971.478] (II) Loading sub module "fb"
[129971.478] (II) LoadModule: "fb"
[129971.478] (II) Loading /usr/lib/xorg/modules/libfb.so
[129971.479] (II) Module fb: vendor="X.Org Foundation"
[129971.479]    compiled for 1.19.5, module version = 1.0.0
[129971.479]    ABI class: X.Org ANSI C Emulation, version 0.4
[129971.479] (II) Loading sub module "wfb"
[129971.479] (II) LoadModule: "wfb"
[129971.480] (II) Loading /usr/lib/xorg/modules/libwfb.so
[129971.480] (II) Module wfb: vendor="X.Org Foundation"
[129971.480]    compiled for 1.19.5, module version = 1.0.0
[129971.480]    ABI class: X.Org ANSI C Emulation, version 0.4
[129971.492] (II) Loading sub module "ramdac"
[129971.492] (II) LoadModule: "ramdac"
[129971.492] (II) Module "ramdac" already built-in
[129971.493] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[129971.493] (++) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[129971.493] (==) NVIDIA(0): RGB weight 888
[129971.493] (==) NVIDIA(0): Default visual is TrueColor
[129971.493] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[129971.493] (**) NVIDIA(0): Option "Stereo" "0"
[129971.494] (**) NVIDIA(0): Option "SLI" "off"
[129971.494] (**) NVIDIA(0): Option "MultiGPU" "Off"
[129971.494] (**) NVIDIA(0): Option "BaseMosaic" "on"
[129971.494] (**) NVIDIA(0): Stereo disabled by request
[129971.494] (**) NVIDIA(0): NVIDIA SLI disabled.
[129971.494] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[129971.494] (**) NVIDIA(0): Option "ConnectedMonitor" "DFP-0,DFP-1,DFP-2,DFP-3"
[129971.494] (**) NVIDIA(0): Enabling 2D acceleration
[129971.494] (**) NVIDIA(0): ConnectedMonitor string: "DFP-0,DFP-1,DFP-2,DFP-3"
[129981.288] (II) NVIDIA(GPU-0): NVIDIA Base Mosaic enabled.
[129982.000] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:176:0:0
[129982.000] (--) NVIDIA(0):     DFP-0
[129982.000] (--) NVIDIA(0):     DFP-1 (boot)
[129982.000] (--) NVIDIA(0):     DFP-2
[129982.000] (--) NVIDIA(0):     DFP-3
[129982.000] (--) NVIDIA(0):     DFP-4
[129982.000] (--) NVIDIA(0):     DFP-5
[129982.000] (--) NVIDIA(0):     DFP-6
[129982.000] (--) NVIDIA(0):     DFP-7
[129982.000] (--) NVIDIA(0): Valid display device(s) on GPU-1 at PCI:19:0:0
[129982.000] (**) NVIDIA(0): Using ConnectedMonitor string "DFP-0, DFP-1, DFP-2, DFP-3".
[129982.005] (II) NVIDIA(0): NVIDIA GPU NVS 510 (GK107) at PCI:176:0:0 (GPU-0)
[129982.005] (--) NVIDIA(0): Memory: 2097152 kBytes
[129982.005] (--) NVIDIA(0): VideoBIOS: 80.07.af.00.0d
[129982.005] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[129982.005] (II) NVIDIA(0): NVIDIA GPU NVS 510 (GK107) at PCI:19:0:0 (GPU-1)
[129982.005] (--) NVIDIA(0): VideoBIOS: 80.07.f1.00.01
[129982.012] (--) NVIDIA(GPU-0): DELL ST2310 (DFP-0): connected
[129982.012] (--) NVIDIA(GPU-0): DELL ST2310 (DFP-0): Internal TMDS
[129982.012] (--) NVIDIA(GPU-0): DELL ST2310 (DFP-0): 165.0 MHz maximum pixel clock
[129982.019] (--) NVIDIA(GPU-0): DELL E207WFP (DFP-1): connected
[129982.019] (--) NVIDIA(GPU-0): DELL E207WFP (DFP-1): Internal TMDS
[129982.019] (--) NVIDIA(GPU-0): DELL E207WFP (DFP-1): 165.0 MHz maximum pixel clock
[129982.115] (--) NVIDIA(GPU-0): ELEFW408 (DFP-2): connected
[129982.115] (--) NVIDIA(GPU-0): ELEFW408 (DFP-2): Internal TMDS
[129982.115] (--) NVIDIA(GPU-0): ELEFW408 (DFP-2): 340.0 MHz maximum pixel clock
[129982.130] (--) NVIDIA(GPU-0): ELEFW408 (DFP-3): connected
[129982.130] (--) NVIDIA(GPU-0): ELEFW408 (DFP-3): Internal TMDS
[129982.130] (--) NVIDIA(GPU-0): ELEFW408 (DFP-3): 340.0 MHz maximum pixel clock
[129982.130] (--) NVIDIA(GPU-0): DFP-4: disconnected
[129982.130] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[129982.130] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[129982.130] (--) NVIDIA(GPU-0): DFP-5: disconnected
[129982.130] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[129982.130] (--) NVIDIA(GPU-0): DFP-5: 960.0 MHz maximum pixel clock
[129982.130] (--) NVIDIA(GPU-0): DFP-6: disconnected
[129982.130] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[129982.130] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[129982.130] (--) NVIDIA(GPU-0): DFP-7: disconnected
[129982.130] (--) NVIDIA(GPU-0): DFP-7: Internal DisplayPort
[129982.130] (--) NVIDIA(GPU-0): DFP-7: 960.0 MHz maximum pixel clock
[129982.147] (--) NVIDIA(GPU-1): DELL E207WFP (DFP-0): connected
[129982.147] (--) NVIDIA(GPU-1): DELL E207WFP (DFP-0): Internal TMDS
[129982.147] (--) NVIDIA(GPU-1): DELL E207WFP (DFP-0): 165.0 MHz maximum pixel clock
[129982.188] (--) NVIDIA(GPU-1): VIZ D43n-E4 (DFP-1): connected
[129982.188] (--) NVIDIA(GPU-1): VIZ D43n-E4 (DFP-1): Internal TMDS
[129982.188] (--) NVIDIA(GPU-1): VIZ D43n-E4 (DFP-1): 340.0 MHz maximum pixel clock
[129982.190] (--) NVIDIA(GPU-1): DFP-2: disconnected
[129982.190] (--) NVIDIA(GPU-1): DFP-2: Internal TMDS
[129982.190] (--) NVIDIA(GPU-1): DFP-2: 165.0 MHz maximum pixel clock
[129982.200] (--) NVIDIA(GPU-1): DFP-3: disconnected
[129982.200] (--) NVIDIA(GPU-1): DFP-3: Internal TMDS
[129982.200] (--) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[129982.200] (--) NVIDIA(GPU-1): DFP-4: disconnected
[129982.200] (--) NVIDIA(GPU-1): DFP-4: Internal DisplayPort
[129982.200] (--) NVIDIA(GPU-1): DFP-4: 960.0 MHz maximum pixel clock
[129982.200] (--) NVIDIA(GPU-1): DFP-5: disconnected
[129982.200] (--) NVIDIA(GPU-1): DFP-5: Internal DisplayPort
[129982.200] (--) NVIDIA(GPU-1): DFP-5: 960.0 MHz maximum pixel clock
[129982.200] (--) NVIDIA(GPU-1): DFP-6: disconnected
[129982.200] (--) NVIDIA(GPU-1): DFP-6: Internal DisplayPort
[129982.200] (--) NVIDIA(GPU-1): DFP-6: 960.0 MHz maximum pixel clock
[129982.200] (--) NVIDIA(GPU-1): DFP-7: disconnected
[129982.200] (--) NVIDIA(GPU-1): DFP-7: Internal DisplayPort
[129982.200] (--) NVIDIA(GPU-1): DFP-7: 960.0 MHz maximum pixel clock
[129982.213] (==) NVIDIA(0):
[129982.213] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[129982.213] (==) NVIDIA(0):     will be used as the requested mode.
[129982.213] (II) NVIDIA(0): Validated MetaModes:
[129982.213] (II) NVIDIA(0):     "DFP-1:nvidia-auto-select,DFP-1:nvidia-auto-select,DFP-0:nvidia-auto-select,DFP-2:nvidia-auto-select,DFP-3:nvidia-auto-select,DFP-0:nvidia-auto-select"
[129982.213] (II) NVIDIA(0): Virtual screen size determined to be 11040 x 1080
[129982.216] (--) NVIDIA(0): DPI set to (99, 98); computed from "UseEdidDpi" X config
[129982.216] (--) NVIDIA(0):     option
[129982.216] (--) Depth 24 pixmap format is 32 bpp
[129982.217] (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
[129982.217] (II) NVIDIA:     access.
[129982.327] (II) NVIDIA(0): Setting mode "DFP-1:nvidia-auto-select,DFP-1:nvidia-auto-select,DFP-0:nvidia-auto-select,DFP-2:nvidia-auto-select,DFP-3:nvidia-auto-select,DFP-0:nvidia-auto-select"
[129982.481] (==) NVIDIA(0): Disabling shared memory pixmaps
[129982.481] (==) NVIDIA(0): Backing store enabled
[129982.481] (==) NVIDIA(0): Silken mouse enabled
[129982.481] (==) NVIDIA(0): DPMS enabled
[129982.481] (II) Loading sub module "dri2"
[129982.481] (II) LoadModule: "dri2"
[129982.481] (II) Module "dri2" already built-in
[129982.481] (II) NVIDIA(0): [DRI2] Setup complete
[129982.481] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[129982.482] (--) RandR disabled
[129982.485] (II) Initializing extension GLX
[129982.485] (II) Indirect GLX disabled.
[129982.665] (II) config/hal: Adding input device keyboard
[129982.665] (**) keyboard: Applying InputClass "keyboard zap by default"
[129982.665] (II) LoadModule: "kbd"
[129982.666] (II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
[129982.666] (II) Module kbd: vendor="X.Org Foundation"
[129982.667]    compiled for 1.19.5, module version = 1.9.0
[129982.667]    Module class: X.Org XInput Driver
[129982.667]    ABI class: X.Org XInput driver, version 24.1
[129982.667] (II) Using input driver 'kbd' for 'keyboard'
[129982.667] (**) keyboard: always reports core events
[129982.667] (**) Option "Device" "/dev/usb/hid2"
[129982.667] (II) keyboard: Opened device "/dev/usb/hid2"
[129982.667] (**) Option "XkbRules" "base"
[129982.667] (**) Option "XkbModel" "sun_type6_usb"
[129982.667] (**) Option "XkbLayout" "us"
[129982.668] (WW) Option "XkbVariant" requires a string value
[129982.668] (**) Option "XkbOptions" "terminate:ctrl_alt_bksp"
[129982.668] (**) Option "config_info" "hal:/org/freedesktop/Hal/devices/pci_0_0/pci108e_4853_1d/hub_1/hub_1/hub_4/hub_4/hub_4/keyboard_4_if0_4_logicaldev_input"
[129982.668] (II) XINPUT: Adding extended input device "keyboard" (type: KEYBOARD, id 6)
[129982.668] (**) Option "StreamsModule" "usbkbm"
[129982.668] (--) keyboard: Keyboard type: USB (6)
[129982.668] (--) keyboard: Keyboard layout: 33
[129982.734] (II) config/hal: Adding input device mouse
[129982.734] (II) LoadModule: "mouse"
[129982.735] (II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
[129982.735] (II) Module mouse: vendor="X.Org Foundation"
[129982.735]    compiled for 1.19.5, module version = 1.9.2
[129982.735]    Module class: X.Org XInput Driver
[129982.735]    ABI class: X.Org XInput driver, version 24.1
[129982.736] (II) Using input driver 'mouse' for 'mouse'
[129982.736] (**) mouse: always reports core events
[129982.736] (**) Option "Protocol" "VUID"
[129982.736] (**) Option "Device" "/dev/usb/hid1"
[129982.736] (**) Option "StreamsModule" "usbms"
[129982.743] (**) mouse: Protocol: "VUID"
[129982.743] (**) mouse: always reports core events
[129982.744] (==) mouse: Emulate3Buttons, Emulate3Timeout: 50
[129982.744] (**) mouse: ZAxisMapping: buttons 4 and 5
[129982.744] (**) mouse: Buttons: 9
[129982.744] (**) Option "config_info" "hal:/org/freedesktop/Hal/devices/pci_0_0/pci108e_4853_1d/hub_1/hub_1/hub_4/hub_4/hub_4/mouse_3_if0_3_logicaldev_input"
[129982.744] (II) XINPUT: Adding extended input device "mouse" (type: MOUSE, id 7)
[129982.744] (**) mouse: (accel) keeping acceleration scheme 1
[129982.744] (**) mouse: (accel) acceleration profile 0
[129982.744] (**) mouse: (accel) acceleration factor: 2.000
[129982.744] (**) mouse: (accel) acceleration threshold: 4
[129983.648] (--) NVIDIA(GPU-0): DELL ST2310 (DFP-0): connected
[129983.648] (--) NVIDIA(GPU-0): DELL ST2310 (DFP-0): Internal TMDS
[129983.648] (--) NVIDIA(GPU-0): DELL ST2310 (DFP-0): 165.0 MHz maximum pixel clock
[129983.655] (--) NVIDIA(GPU-0): DELL E207WFP (DFP-1): connected
[129983.655] (--) NVIDIA(GPU-0): DELL E207WFP (DFP-1): Internal TMDS
[129983.655] (--) NVIDIA(GPU-0): DELL E207WFP (DFP-1): 165.0 MHz maximum pixel clock
[129983.756] (--) NVIDIA(GPU-0): ELEFW408 (DFP-2): connected
[129983.756] (--) NVIDIA(GPU-0): ELEFW408 (DFP-2): Internal TMDS
[129983.756] (--) NVIDIA(GPU-0): ELEFW408 (DFP-2): 340.0 MHz maximum pixel clock
[129983.772] (--) NVIDIA(GPU-0): ELEFW408 (DFP-3): connected
[129983.772] (--) NVIDIA(GPU-0): ELEFW408 (DFP-3): Internal TMDS
[129983.772] (--) NVIDIA(GPU-0): ELEFW408 (DFP-3): 340.0 MHz maximum pixel clock
[129983.772] (--) NVIDIA(GPU-0): DFP-4: disconnected
[129983.772] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[129983.772] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[129983.772] (--) NVIDIA(GPU-0): DFP-5: disconnected
[129983.772] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[129983.773] (--) NVIDIA(GPU-0): DFP-5: 960.0 MHz maximum pixel clock
[129983.773] (--) NVIDIA(GPU-0): DFP-6: disconnected
[129983.773] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[129983.773] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[129983.773] (--) NVIDIA(GPU-0): DFP-7: disconnected
[129983.773] (--) NVIDIA(GPU-0): DFP-7: Internal DisplayPort
[129983.773] (--) NVIDIA(GPU-0): DFP-7: 960.0 MHz maximum pixel clock
[129983.797] (--) NVIDIA(GPU-1): DELL E207WFP (DFP-0): connected
[129983.797] (--) NVIDIA(GPU-1): DELL E207WFP (DFP-0): Internal TMDS
[129983.797] (--) NVIDIA(GPU-1): DELL E207WFP (DFP-0): 165.0 MHz maximum pixel clock
[129983.838] (--) NVIDIA(GPU-1): VIZ D43n-E4 (DFP-1): connected
[129983.838] (--) NVIDIA(GPU-1): VIZ D43n-E4 (DFP-1): Internal TMDS
[129983.838] (--) NVIDIA(GPU-1): VIZ D43n-E4 (DFP-1): 340.0 MHz maximum pixel clock
[129983.840] (--) NVIDIA(GPU-1): DFP-2: disconnected
[129983.840] (--) NVIDIA(GPU-1): DFP-2: Internal TMDS
[129983.840] (--) NVIDIA(GPU-1): DFP-2: 165.0 MHz maximum pixel clock
[129983.850] (--) NVIDIA(GPU-1): DFP-3: disconnected
[129983.850] (--) NVIDIA(GPU-1): DFP-3: Internal TMDS
[129983.850] (--) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[129983.850] (--) NVIDIA(GPU-1): DFP-4: disconnected
[129983.850] (--) NVIDIA(GPU-1): DFP-4: Internal DisplayPort
[129983.850] (--) NVIDIA(GPU-1): DFP-4: 960.0 MHz maximum pixel clock
[129983.850] (--) NVIDIA(GPU-1): DFP-5: disconnected
[129983.850] (--) NVIDIA(GPU-1): DFP-5: Internal DisplayPort
[129983.851] (--) NVIDIA(GPU-1): DFP-5: 960.0 MHz maximum pixel clock
[129983.851] (--) NVIDIA(GPU-1): DFP-6: disconnected
[129983.851] (--) NVIDIA(GPU-1): DFP-6: Internal DisplayPort
[129983.851] (--) NVIDIA(GPU-1): DFP-6: 960.0 MHz maximum pixel clock
[129983.851] (--) NVIDIA(GPU-1): DFP-7: disconnected
[129983.851] (--) NVIDIA(GPU-1): DFP-7: Internal DisplayPort
[129983.851] (--) NVIDIA(GPU-1): DFP-7: 960.0 MHz maximum pixel clock
[129984.538] (II) NVIDIA(0): Setting mode "GPU-0.DP-1: nvidia-auto-select @1680x1050 +0+0 {ViewPortIn=1680x1050, ViewPortOut=1680x1050+0+0}, GPU-0.DP-0: nvidia-auto-select @1920x1080 +3600+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-0.DP-2: nvidia-auto-select @1920x1080 +7200+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-0.DP-3: nvidia-auto-select @1920x1080 +5520+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-1.DP-1: nvidia-auto-select @1920x1080 +1680+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-1.DP-0: nvidia-auto-select @1680x1050 +5520+0 {ViewPortIn=1680x1050, ViewPortOut=1680x1050+0+0}"
[129984.758] (II) NVIDIA(0): Setting mode "GPU-0.DP-1: nvidia-auto-select @1680x1050 +1920+0 {ViewPortIn=1680x1050, ViewPortOut=1680x1050+0+0}, GPU-0.DP-0: nvidia-auto-select @1920x1080 +3600+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-0.DP-2: nvidia-auto-select @1920x1080 +7200+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-0.DP-3: nvidia-auto-select @1920x1080 +5520+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-1.DP-1: nvidia-auto-select @1920x1080 +1680+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-1.DP-0: nvidia-auto-select @1680x1050 +5520+0 {ViewPortIn=1680x1050, ViewPortOut=1680x1050+0+0}"
[129984.974] (II) NVIDIA(0): Setting mode "GPU-0.DP-1: nvidia-auto-select @1680x1050 +1920+0 {ViewPortIn=1680x1050, ViewPortOut=1680x1050+0+0}, GPU-0.DP-0: nvidia-auto-select @1920x1080 +3600+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-0.DP-2: nvidia-auto-select @1920x1080 +7200+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-0.DP-3: nvidia-auto-select @1920x1080 +5520+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-1.DP-0: nvidia-auto-select @1680x1050 +7440+0 {ViewPortIn=1680x1050, ViewPortOut=1680x1050+0+0}"
[129985.219] (II) NVIDIA(0): Setting mode "GPU-0.DP-1: nvidia-auto-select @1680x1050 +1920+0 {ViewPortIn=1680x1050, ViewPortOut=1680x1050+0+0}, GPU-0.DP-0: nvidia-auto-select @1920x1080 +3600+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-0.DP-2: nvidia-auto-select @1920x1080 +3600+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-0.DP-3: nvidia-auto-select @1920x1080 +5520+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-1.DP-0: nvidia-auto-select @1680x1050 +7440+0 {ViewPortIn=1680x1050, ViewPortOut=1680x1050+0+0}"
[129985.409] (II) NVIDIA(0): Setting mode "GPU-0.DP-1: nvidia-auto-select @1680x1050 +1920+0 {ViewPortIn=1680x1050, ViewPortOut=1680x1050+0+0}, GPU-0.DP-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-0.DP-2: nvidia-auto-select @1920x1080 +3600+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-0.DP-3: nvidia-auto-select @1920x1080 +5520+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-1.DP-0: nvidia-auto-select @1680x1050 +7440+0 {ViewPortIn=1680x1050, ViewPortOut=1680x1050+0+0}"
[129985.599] (II) NVIDIA(0): Setting mode "GPU-0.DP-1: nvidia-auto-select @1680x1050 +1920+0 {ViewPortIn=1680x1050, ViewPortOut=1680x1050+0+0}, GPU-0.DP-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-0.DP-2: nvidia-auto-select @1920x1080 +3600+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-0.DP-3: nvidia-auto-select @1920x1080 +5520+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-1.DP-0: nvidia-auto-select @1680x1050 +7440+0 {ViewPortIn=1680x1050, ViewPortOut=1680x1050+0+0}, GPU-1.DP-1: nvidia-auto-select @1920x1080 +9120+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[129987.043] (--) NVIDIA(GPU-0): DELL ST2310 (DFP-0): connected
[129987.043] (--) NVIDIA(GPU-0): DELL ST2310 (DFP-0): Internal TMDS
[129987.043] (--) NVIDIA(GPU-0): DELL ST2310 (DFP-0): 165.0 MHz maximum pixel clock
[129987.050] (--) NVIDIA(GPU-0): DELL E207WFP (DFP-1): connected
[129987.050] (--) NVIDIA(GPU-0): DELL E207WFP (DFP-1): Internal TMDS
[129987.050] (--) NVIDIA(GPU-0): DELL E207WFP (DFP-1): 165.0 MHz maximum pixel clock
[129987.147] (--) NVIDIA(GPU-0): ELEFW408 (DFP-2): connected
[129987.147] (--) NVIDIA(GPU-0): ELEFW408 (DFP-2): Internal TMDS
[129987.147] (--) NVIDIA(GPU-0): ELEFW408 (DFP-2): 340.0 MHz maximum pixel clock
[129987.163] (--) NVIDIA(GPU-0): ELEFW408 (DFP-3): connected
[129987.163] (--) NVIDIA(GPU-0): ELEFW408 (DFP-3): Internal TMDS
[129987.163] (--) NVIDIA(GPU-0): ELEFW408 (DFP-3): 340.0 MHz maximum pixel clock
[129987.163] (--) NVIDIA(GPU-0): DFP-4: disconnected
[129987.163] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[129987.163] (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
[129987.163] (--) NVIDIA(GPU-0): DFP-5: disconnected
[129987.163] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[129987.163] (--) NVIDIA(GPU-0): DFP-5: 960.0 MHz maximum pixel clock
[129987.163] (--) NVIDIA(GPU-0): DFP-6: disconnected
[129987.163] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[129987.163] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[129987.163] (--) NVIDIA(GPU-0): DFP-7: disconnected
[129987.163] (--) NVIDIA(GPU-0): DFP-7: Internal DisplayPort
[129987.163] (--) NVIDIA(GPU-0): DFP-7: 960.0 MHz maximum pixel clock
[129987.187] (--) NVIDIA(GPU-1): DELL E207WFP (DFP-0): connected
[129987.187] (--) NVIDIA(GPU-1): DELL E207WFP (DFP-0): Internal TMDS
[129987.187] (--) NVIDIA(GPU-1): DELL E207WFP (DFP-0): 165.0 MHz maximum pixel clock
[129987.228] (--) NVIDIA(GPU-1): VIZ D43n-E4 (DFP-1): connected
[129987.228] (--) NVIDIA(GPU-1): VIZ D43n-E4 (DFP-1): Internal TMDS
[129987.228] (--) NVIDIA(GPU-1): VIZ D43n-E4 (DFP-1): 340.0 MHz maximum pixel clock
[129987.230] (--) NVIDIA(GPU-1): DFP-2: disconnected
[129987.230] (--) NVIDIA(GPU-1): DFP-2: Internal TMDS
[129987.230] (--) NVIDIA(GPU-1): DFP-2: 165.0 MHz maximum pixel clock
[129987.240] (--) NVIDIA(GPU-1): DFP-3: disconnected
[129987.240] (--) NVIDIA(GPU-1): DFP-3: Internal TMDS
[129987.240] (--) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[129987.240] (--) NVIDIA(GPU-1): DFP-4: disconnected
[129987.240] (--) NVIDIA(GPU-1): DFP-4: Internal DisplayPort
[129987.240] (--) NVIDIA(GPU-1): DFP-4: 960.0 MHz maximum pixel clock
[129987.240] (--) NVIDIA(GPU-1): DFP-5: disconnected
[129987.240] (--) NVIDIA(GPU-1): DFP-5: Internal DisplayPort
[129987.240] (--) NVIDIA(GPU-1): DFP-5: 960.0 MHz maximum pixel clock
[129987.241] (--) NVIDIA(GPU-1):
[129987.241] (--) NVIDIA(GPU-1): DFP-6: disconnected
[129987.241] (--) NVIDIA(GPU-1): DFP-6: Internal DisplayPort
[129987.241] (--) NVIDIA(GPU-1): DFP-6: 960.0 MHz maximum pixel clock
[129987.241] (--) NVIDIA(GPU-1): DFP-7: disconnected
[129987.241] (--) NVIDIA(GPU-1): DFP-7: Internal DisplayPort
[129987.241] (--) NVIDIA(GPU-1): DFP-7: 960.0 MHz maximum pixel clock
Also, xdpyinfo:
name of display:    :0
version number:    11.0
vendor string:    Oracle Corporation, based on X.Org Foundation sources
vendor release number:    11905000
X.Org version: 1.19.5
maximum request size:  16777212 bytes
motion buffer size:  256
bitmap unit, bit order, padding:    32, LSBFirst, 32
image byte order:    LSBFirst
number of supported pixmap formats:    7
    depth 1, bits_per_pixel 1, scanline_pad 32
    depth 4, bits_per_pixel 8, scanline_pad 32
    depth 8, bits_per_pixel 8, scanline_pad 32
    depth 15, bits_per_pixel 16, scanline_pad 32
    depth 16, bits_per_pixel 16, scanline_pad 32
    depth 24, bits_per_pixel 32, scanline_pad 32
    depth 32, bits_per_pixel 32, scanline_pad 32
keycode range:    minimum 8, maximum 255
focus:  window 0xc00009, revert to PointerRoot
number of extensions:    31
    BIG-REQUESTS
    Composite
    DAMAGE
    DOUBLE-BUFFER
    DPMS
    DRI2
    GLX
    Generic Event Extension
    MIT-SCREEN-SAVER
    MIT-SHM
    NV-CONTROL
    NV-GLX
    Present
    RANDR
    RECORD
    RENDER
    SECURITY
    SHAPE
    SYNC
    SolarisIA
    X-Resource
    XC-MISC
    XFIXES
    XFree86-DGA
    XFree86-VidModeExtension
    XINERAMA
    XINERAMA
    XInputExtension
    XKEYBOARD
    XTEST
    XVideo
default screen number:    0
number of screens:    1
screen #0:
  dimensions:    11040x1080 pixels (2921x286 millimeters)
  resolution:    96x96 dots per inch
  depths (7):    24, 1, 4, 8, 15, 16, 32
  root window id:    0x2b6
  depth of root window:    24 planes
  number of colormaps:    minimum 1, maximum 1
  default colormap:    0x20
  default number of colormap cells:    256
  preallocated pixels:    black 0, white 16777215
  options:    backing-store WHEN MAPPED, save-unders NO
  largest cursor:    256x256
  current input event mask:    0xfa0003
    KeyPressMask             KeyReleaseMask           StructureNotifyMask
    SubstructureNotifyMask   SubstructureRedirectMask FocusChangeMask
    PropertyChangeMask       ColormapChangeMask
  number of visuals:    228
  default visual id:  0x21
  visual:
    visual id:    0x21
    class:    TrueColor
    depth:    24 planes
    available colormap entries:    256 per subfield
    red, green, blue masks:    0xff0000, 0xff00, 0xff
    significant bits in color specification:    11 bits
<snip>
Ok, after working on this forever, I finally “solved” it. The problem is with permissions on /dev/nvidiactl and /dev/nvidia-modeset.
After logging in, /dev/nvidia0, and /dev/nvidia1 in my case, are changed ownership to whomever logged in, however /dev/nvidiactl and /dev/nvidia-modeset are still owned by root with no permissions for any other groups/users.
As a band-aid, I added permissions for the group owner, gdm, to have r/w access, and added users that would log in to the gdm group. I figure this is maybe slightly better than having it all open.
Anyway, with permissions set, then GL apps, including clutter, work just fine.
I’m not sure where this bug really lies, but if anyone at nvidia is interested I can certainly try to provide assistance.
