I am trying to run a basic object detection code from a video file using jetson inference library. However i run into this error which i have no clue on how to fix.
import jetson_utils_python
import jetson_inference_python
import cv2
net= jetson_inference_python.detectNet('ssd-mobilenet-v2', threshold = 0.5)
cam= jetson_utils_python.videoSource("/home/nvidia/Desktop/Project_Files/CarsDrivingUnderBridge.mp4")
display= jetson_utils_python.glDisplay()
while display.IsOpen():
img, width, height= cam.Capture()
detections= net.Detect(img, width, height)
display.RenderOnce(img, width, height)
This is the error i got
detectNet -- loading detection network model from:
-- model networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
-- input_blob 'Input'
-- output_blob 'NMS'
-- output_count 'NMS_1'
-- class_labels networks/SSD-Mobilenet-v2/ssd_coco_labels.txt
-- threshold 0.500000
-- batch_size 1
[TRT] TensorRT version 7.1.0
[TRT] loading NVIDIA plugins...
[TRT] Plugin creator registration succeeded - ::GridAnchor_TRT
[TRT] Plugin creator registration succeeded - ::NMS_TRT
[TRT] Plugin creator registration succeeded - ::Reorg_TRT
[TRT] Plugin creator registration succeeded - ::Region_TRT
[TRT] Plugin creator registration succeeded - ::Clip_TRT
[TRT] Plugin creator registration succeeded - ::LReLU_TRT
[TRT] Plugin creator registration succeeded - ::PriorBox_TRT
[TRT] Plugin creator registration succeeded - ::Normalize_TRT
[TRT] Plugin creator registration succeeded - ::RPROI_TRT
[TRT] Plugin creator registration succeeded - ::BatchedNMS_TRT
[TRT] Could not register plugin creator: ::FlattenConcat_TRT
[TRT] Plugin creator registration succeeded - ::CropAndResize
[TRT] Plugin creator registration succeeded - ::DetectionLayer_TRT
[TRT] Plugin creator registration succeeded - ::Proposal
[TRT] Plugin creator registration succeeded - ::ProposalLayer_TRT
[TRT] Plugin creator registration succeeded - ::PyramidROIAlign_TRT
[TRT] Plugin creator registration succeeded - ::ResizeNearest_TRT
[TRT] Plugin creator registration succeeded - ::Split
[TRT] Plugin creator registration succeeded - ::SpecialSlice_TRT
[TRT] Plugin creator registration succeeded - ::InstanceNormalization_TRT
[TRT] detected model format - UFF (extension '.uff')
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.7100.GPU.FP16.engine
[TRT] loading network plan from engine cache... /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.7100.GPU.FP16.engine
[TRT] device GPU, loaded /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
[TRT] Deserialize required 2533827 microseconds.
[TRT]
[TRT] CUDA engine context initialized on device GPU:
[TRT] -- layers 118
[TRT] -- maxBatchSize 1
[TRT] -- workspace 0
[TRT] -- deviceMemory 22350848
[TRT] -- bindings 3
[TRT] binding 0
-- index 0
-- name 'Input'
-- type FP32
-- in/out INPUT
-- # dims 3
-- dim #0 3 (SPATIAL)
-- dim #1 300 (SPATIAL)
-- dim #2 300 (SPATIAL)
[TRT] binding 1
-- index 1
-- name 'NMS'
-- type FP32
-- in/out OUTPUT
-- # dims 3
-- dim #0 1 (SPATIAL)
-- dim #1 100 (SPATIAL)
-- dim #2 7 (SPATIAL)
[TRT] binding 2
-- index 2
-- name 'NMS_1'
-- type FP32
-- in/out OUTPUT
-- # dims 3
-- dim #1 1 (SPATIAL)
-- dim #2 1 (SPATIAL)
[TRT]
[TRT] binding to input 0 Input binding index: 0
[TRT] binding to input 0 Input dims (b=1 c=3 h=300 w=300) size=1080000
[TRT] binding to output 0 NMS binding index: 1
[TRT] binding to output 0 NMS dims (b=1 c=1 h=100 w=7) size=2800
[TRT] binding to output 1 NMS_1 binding index: 2
[TRT] binding to output 1 NMS_1 dims (b=1 c=1 h=1 w=1) size=4
[TRT]
[TRT] device GPU, /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff initialized.
[TRT] W = 7 H = 100 C = 1
[TRT] detectNet -- maximum bounding boxes: 100
[TRT] detectNet -- loaded 91 class info entries
[TRT] detectNet -- number of object classes: 91
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstDecoder -- creating decoder for /home/nvidia/Desktop/Project_Files/CarsDrivingUnderBridge.mp4
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
[gstreamer] gstDecoder -- discovered video resolution: 1280x720 (framerate 29.970030 Hz)
[gstreamer] gstDecoder -- discovered video caps: video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)constrained-baseline, width=(int)1280, height=(int)720, framerate=(fraction)30000/1001, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
[gstreamer] gstDecoder -- pipeline string:
[gstreamer] filesrc location=/home/nvidia/Desktop/Project_Files/CarsDrivingUnderBridge.mp4 ! qtdemux ! queue ! h264parse ! omxh264dec ! video/x-raw ! appsink name=mysink
[video] created gstDecoder from file:///home/nvidia/Desktop/Project_Files/CarsDrivingUnderBridge.mp4
gstDecoder video options:
-- URI: file:///home/nvidia/Desktop/Project_Files/CarsDrivingUnderBridge.mp4
- protocol: file
- location: /home/nvidia/Desktop/Project_Files/CarsDrivingUnderBridge.mp4
- extension: mp4
-- deviceType: file
-- ioType: input
-- codec: h264
-- width: 1280
-- height: 720
-- frameRate: 29.970030
-- bitRate: 0
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
[OpenGL] glDisplay -- X screen 0 resolution: 1920x1080
[OpenGL] glDisplay -- X window resolution: 1920x1080
[OpenGL] failed to create X11 Window.
[OpenGL] failed to create OpenGL window
File "/home/nvidia/Desktop/Project_Files/PyProjects/jetson_infer_OpenCV.py", line 15, in <module>
Exception: jetson.utils -- failed to create glDisplay device
How do i get the gldisplay to work in the code?
