Issue at Tegra Graphics Debugger
after export display:0 command in tx1,when executing
LD_PRELOAD=~/.tgd/libs/libNvidia_gfx_debugger.so ./bubble
error is opengl extensions are missing
Hi, I was having the same problem. It went away after rebooting both the TX1 and the remote host.
After the reboot, I connected the Tegra Graphics Debugger to the TX1 and it said the debugging tools weren’t installed. I clicked the button to install them & after that was able to debug successfully.
Hope that helps,
Vil
hai vilya…thanks for the reply.
please tell me what you did after the step :LD_PRELOAD=~/.tgd/libs/libNvidia_gfx_debugger.so ./bubble
