I am trying to get object detection running on my Xavier NX but somehow I can’t get the output on my display (HDMI monitor). When I supply a file for output it works fine.
Output:
[OpenGL] glDisplay -- X screen 0 resolution: 2560x1440
[OpenGL] glDisplay -- X window resolution: 2560x1440
[OpenGL] failed to create X11 Window.
jetson.utils -- no output streams, creating fake null output
After which it will render to a fake output.
The code is mainly copied from this:
I have found similar topics but none of them contain a conclusive solution… I have tried $ export DISPLAY=:0
with no result. How can I try to troubleshoot this?
Not sure for your case, but I’ve faced the same once when using a RTSP video source.
I can’t tell what was the root cause, but the workaround was to create the GL sink before the video source.
